Often I deal with rather large MKV files, sometimes in excess of 30GB. Often I need to make a minor change to the file, such as making a subtitle track a non-default track. I imagine some modifications wouldn't add any more data to the MKV, so my question is, does anyone know of a tool that make certain changes to an MKV without re-writing the entire file?
I currently use MKVToolnix for all of my MKV needs.
Try mkvpropedit that is included in mkvtoolnix. Only a command line app though.
Ok, mkvpropedit kicks ass. Here's what I did to turn off the default subtitles track:
1) Open the file in MKV Merge GUI to easily view the properties of the file.
2) Note the number of the track that you want to modify (e.g. 1 for the first track)
3) Run the following command: mkvpropedit --edit track:1 --set flag-default=0 "E:\Example.mkv"
4) Marvel at the instant modification.
Some handy documentation can be found here: http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvpropedit.html
Someone needs to write a GUI for this app though as I fear it's being severely under used.
Tools for editing MKV file.
By wisitch in forum EditingReplies: 2Last Post: 9th Oct 2010, 00:31 -
Help with editing mkv file
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2010, 17:55 -
Disc writing tool not working in TMPGEnc dvd authoring 4
By egor909 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2009, 05:14 -
MKVExtractGUI does not demux entire mkv?
By avkhatri in forum Video ConversionReplies: 9Last Post: 7th Feb 2009, 19:03 -
Problem viewing/editing entire .mpg video
By auriel in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2008, 00:47
