Now before I start, I've found and followed these threads to a T:
https://forum.videohelp.com/threads/310525-Load-AVCHD-Lite-mts-files-into-VirtualDub
https://forum.videohelp.com/threads/306447-Converting-AVCHD-to-jpeg-s
Using both methods (the plugin, and using the Avisynth script), I can load the video file into Vdub. It reads the correct number of frames, but it never shows the video. When I try to export an image sequence, they're solid gray, or solid black. No idea why. Doesn't matter if I load it with the script, or using the direct show driver plugin. Same results, both times.
I have ffdshow, and Haali Media Splitter installed. I've tried every recent version of Vdub 32-bit, as none of the methods in the above threads seem to work _at all_ in a 64-bit version. It seems like I'm so close, but I just cannot figure what's going on.
For footage I've got some stuff I shot earlier with my Panasonic HDC-TM90. They were recorded at 1080p - 60FPS @ 28mbit. Is the 60FPS what's causing my issue here? VLC plays them just fine.
Many huge thanks in advance.
AnonymousGuest
can't get ffmpeg to convert video to image sequence
By wiseant in forum Video ConversionReplies: 15Last Post: 12th Apr 2013, 08:37 -
CLI batch Vdub Image Sequence
By corsiva in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 12:49 -
Image sequence and easy x264 GUI
By Bucic in forum EditingReplies: 5Last Post: 4th Oct 2010, 16:03 -
Convert DVD to JPG sequence by any second interval?
By omega_weapon in forum EditingReplies: 3Last Post: 29th Jan 2009, 17:01 -
best compression for image sequence movie ??
By mehdi0016 in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2007, 09:17
