Is it possible to convert a AVCHD (MTS) video into JPEG's, so a 5 minute movie at 30 fps becomes 9,000 JPEG's? Thanks.
You can do it with avisynth + virtualdub
Install haali media splitter, ffdshow, avisynth
Open a text file with notepad in the same directory as your .mts file, write the following, then change the extension from .txt to .avs (change the filename to match):
DirectShowSource("file.mts")
Then open that .avs file in virtualdub, file=>export=>image sequence and choose your settings for export (e.g. jpg, quality, etc...) -
I followed the instructions, but the VirtualDub program won't open the .avs file.
Any suggestions?
Problem converting combined motion jpeg and mp4 audio file into other forma
By Anonymous3 in forum Video ConversionReplies: 49Last Post: 31st Aug 2011, 17:14 -
AVCHD (1080i) ve Motion JPEG (HD)
By pemongillo in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2011, 21:05 -
converting .jpeg into video format for slideshow
By rosmari in forum Video ConversionReplies: 40Last Post: 1st Aug 2009, 10:23 -
Converting Mkv to AVCHD
By ranosb in forum Video ConversionReplies: 1Last Post: 9th May 2009, 06:25 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 05:14
