Hi guys!
Today I noticed the program ffmpegx for Mac and the program is quite understandable. But I have a problem. After I checked the guided tour or how to make avi do dvd everything worked and the encoding proccess has been working. After the encoding was done I tried to open the folder (that I created for the new DVD) and there was NO Video_TS or Audio_TS. What is teh problem??
Please help!!
Bye
	No log output/file?
 And you are not alone, https://forum.videohelp.com/threads/284332-No-Video_TS-Folder
	ffmpegX should output an .mpg file first, from which it will make a .DVD folder with a VIDEO_TS and AUDIO_TS folder.
 The ffmpegX Progress window should show "Finished" with a magnifying glass icon next to it, which acts as a button to show the output in the Finder, so you don't have to search for it.
 If the ffmpegX Progress window shows "Failed", then please click the blue icon with the "i" next to it, to show the Process Information log. This log should help finding out what happened, so we can try to fix if needed.
 (Please be advised that Videohelp.com has a special ffmpegX forum.)
	Oops. Never mind. Last edited by rumplestiltskin; 30th Jun 2011 at 16:34.
  AVI TO DVD - MAC OS XBy westerndevon in forum MacReplies: 7Last Post: 15th Jan 2011, 15:02
  Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PROBy krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18
  Converting AVI to Video TS using macBy DonRay in forum MacReplies: 16Last Post: 1st Jul 2009, 20:10
  WMV to AVI using Xilisoft Mac Video ConverterBy BassJunkie in forum MacReplies: 11Last Post: 30th Jul 2008, 03:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
