    Feb 2008
    Canada
    So this is my 2847583th time trying to encode a movie from avi to dvd format. I've only made it through the whole process one or two times with the Video_TS folder. Usually I can't even get the log to open before ffmpegx suddenly quits or has to be forced to quit, but I've got it now. Any suggestions as to what's happening?
    INFO: [mpeg2enc] Worker: getting
    INFO: [mpeg2enc] Enc1 144472 144472( 6) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Working: stripe 0/1 1
    INFO: [mpeg2enc] Worker: stripe 0 done
    INFO: [mpeg2enc] Enc1 144473 144473( 7) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 144474 144474( 8) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 144475 144475( 9) P q=3.00 [0% Intra]
    INFO: [yuvscaler] End of stream!
    INFO: [yuvscaler] Normal exit: end of stream with frame number 144477!
    INFO: [mpeg2enc] Signaling last frame = 144476
    INFO: [mpeg2enc] Enc1 144476 144476(10) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Sequence end inserted
    INFO: [mpeg2enc] Guesstimated final muxed size = 2295869472
    INFO: [mpeg2enc] SHUTDOWN worker
    error: could not create save file!
    I'm confused.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Possibly your Mac needs some maintenance (/Applications/Utilities/Disk Utility.app), as ffmpegX is quite stable for most people.
    The log you posted is only partial, which makes it impossible to see if there are any clues to errors in the first part. However, I agree that "could not create save file" isn't very descriptive by the developers on the reasons why it couldn't do what it needed to do.
