The Adobe Acrobat Reader save and open location is My Documents, and I have to browse to folder where I want files saved or opened. Is there a way to change that to another location chosen by the user without having to do multiple clicks to browse to desired location?
	Right-click the shortcut (either on the desktop or in the Start menu) that you use to launch Reader, and click Properties. There should be an entry box in the shortcut properties for the folder/directory you want the program to start in when you open it. In Vista, you'd click on the Shortcut tab, then edit the "Start in:" field. I don't know what Win2K uses, or remember what XP and 9X used, offhand. (I'd have to boot our XP and 9X systems just to check... well, and my Win3 system, too.  )
						If cameras add ten pounds, why would people want to eat them? )
	I found the empty box and entered the start in location clicked apply and OK, but it still starts in My Documents instead. Why won't in start in the location entered?
	Dunno about the box but my Acrobat opens in the folder that was last read from and its not 'My Documents'
	The "Start in:" field of the shortcuts is the 'default' way to do it, but programs don't always seem to honor it. I'll have to experiment with Reader and see what happens. (I usually just double-click on a PDF in Explorer to view, rather than go through Acrobat's menus.  ) )
 Edit: Okay, I've checked Reader 9 (9.4.3) on Vista. (I don't remember, offhand, if there's a limit to the versions you can use with Win2K, unfortunately.)
 Used Open > navigated to a new folder with PDFs and then opened one of the PDFs, then closed Reader. Started Reader again, and Open called up the same folder. That didn't change if I picked a new PDF from the old directory in the Recent Files list, double-clicked on a PDF from Explorer, or closed Reader without opening a PDF.
 So, it does seem to remember the directory in which you last opened a PDF. I'm not sure how well, though.  Last edited by Ai Haibara; 24th May 2011 at 15:41. If cameras add ten pounds, why would people want to eat them?
	It appears it's a version issue. I was running Reader 7 and tried Reader 8 with same result. After reading the Ai Haibara post, I tried Reader 9, and it now opens in same location as last file opened which is I wanted.
  Adobe ReaderBy Jomapil in forum ComputerReplies: 3Last Post: 2nd Mar 2011, 09:32
  Distributing Acrobat Reader on CD-ROMBy xavierp in forum ComputerReplies: 7Last Post: 10th May 2010, 12:53
  Adobe Acrobat conversionBy bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2009, 00:27
  Acrobat Reader - process in RAMBy Ai Haibara in forum ComputerReplies: 5Last Post: 3rd Jan 2009, 02:48
  How to save a Power Point program with audio to different location?By Captain Satellite in forum ComputerReplies: 8Last Post: 24th Jun 2007, 00:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
