Any way to fix some bad queuing in audio channels that occurred from me using DKAudio v.0.1.9 beta for DTS to AC3?
By the time I noticed that the speech channel was coming from the front speaker the original DTS file was gone. So now I just have to put the channels in the right order, only... 2 questions.
Which is the right way? - That is, how does DKAudio sorts each channel? -
And how to do that?
I'm trying to find a way to correct this whole mess directly from the ac3.
I've noticed the commands in Eac3to, specifically
so I bet I could use that to fix the messed up AC3s if I were to use something likeCode:-0,1,2,3,4,5 (remap the channels...)
or something like that? Am I correct?Code:eac3to.exe file.ac3 file.ac3 -384 -1,2,3,0,4,5
Only, I still don't know how the DKAudio orders the channels in the first place. I know the speech comes from the front speakers but only that, and then that's channel what? 0-1? 2-3? 3-4?
Yet another thing I noticed in eac3to was the command to apply some positive or negative gain to the file created
on AC3s that's very useful.Code:+/-3dB apply a positive or..
But when the encoder runs, no matter how much I push the gain upwards, it automatically pushes it back to a preset. If I add 1, it subtracts a number+1 till it matches that preset, if I add 10, that same.
Is there a specified volume which ac3s can't exceed?
Or is this a program default setting? If so, how to undo that setting or change it to my needs?
e.g. I found the post https://forum.videohelp.com/threads/258002-Mini-How-To-Increase-Your-AC3-Volume and that way works for me, however I was hoping to find a way to do everything in one encode if possible, using eac3to only.
So, anyone?
-Good Things Come to Those Who Wait- -
Usually, an AC3 file will have the following ordering:
0 -> Left Front
1 -> Center
2 -> Right Front
3 -> Left Surround (or Rear)
4 -> Right Surround (or Rear)
5 -> LFEICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
So that's how ac3 should be! Then what is the order for the DTS?
I'm thinking maybe this is where DKAudio did wrong. So if I knew both orders, maybe I could correct this.-Good Things Come to Those Who Wait- -
Ok, after huge extensive testing and experimentation and the help of a more mathematically inclined mind than my own, I finally cracked the wrong channel order "code"
Using this command line in eac3to will fix all the channels that were placed incorrectly, however the Right Rear(Side Rear) channel sounds like it's coming from an underwater cavern. I guess when the channels were messed up, the RR was wrongly placed in the place of the LFE and the effect caused is due to the specific processing being done for it to play on the specific speaker. Very high bass, almost non existent tremble, or something like that.Code:eac3to.exe file.ac3 file_ch_fix.ac3 -0,2,1,4,5,3
Anyway, the question that derives from that now is if there is any way to restore it, not entirely to the 100% of it's original form, but close enough, just not to be annoying. I'm attaching the corrected test ac3 for anyone to hear. file_ch_fix.ac3
It's in the fifth part of the file, sounding at about 6-7 secs.-Good Things Come to Those Who Wait-
AC3 channels are split incorrectly
By silvertoaster in forum AudioReplies: 2Last Post: 23rd May 2011, 22:10 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 14:12 -
Dolby AC3 5 channels - voices are not playing
By dexter30 in forum AudioReplies: 1Last Post: 28th Oct 2009, 16:58 -
MKVs: downmix ac3 6-channels to ac3 2-channels and remux
By kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 16:07 -
AC3 to WAV (MUST KEEP 6 CHANNELS)
By RushMaster in forum AudioReplies: 6Last Post: 17th Oct 2007, 04:03
