    Mar 2011
    India
    Hi All,
    Can anyone please explain as to how mpeg-ts works. I have gone through the specification doc but didnt understood as to why multiple streams are combined to form one stream.
    Also I opened a .ts file using media info tool and for Audio it was showing 2 Audio streams. So which audio stream will be used while playing the content.
  2. Member Cornucopia's Avatar
    Simply put, streams are combined (the industry term is "multiplexed", or "muxed") to keep them together, both for synchronization purposes, and to keep their various sections from getting misplaced/fragmented.
    All the major containers multiplex their streams, some more than others.
    Which streams are preferred is either a A) player/user choice, or (in the case of DVD/BD authored discs) B) authored VM logic.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    http://www.kiva.org/about
