Results 1 to 30 of 41
  1. Ok, so I've converted a file that is a HD 1080i TS file with StaxRip 1.1.7.0 Beta Version. I used Xvid - MP4 as converting settings. I'm a totally noob to StaxRip, and I am not really sure on how to do stuff with it.
    So I converted it, and everything went successfully. I choose to not have the Audio because I was going to edit it and stuff. Then when I went to Vegas Pro 9.0 and imported it, it wouldn't play as normal, and the screen went black on the preview. I've got to know that the DivX to Avi is the best settings for these types of files, but I don't know why. And when I chose DivX - AVI VirtualDub popped up and said: ''Video Compression Error: The Source Image blah blah''. I've seen this is a common error, but I don't understand how to fix this, and get on the editing. And StaxRip uses waay to long to convert those files. About 3-4 hours. So please, can anyone help?
  2. why can't you import the original file ?
    what are the specifications and where is it from ? use mediainfo
  3. Originally Posted by poisondeathray View Post
    Well, I can't import it directly because it has too many errors and warnings. I scanned it with TSDoctor.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Vegas Pro 9 will import the 1080i MPeg2 TS files (as broadcast) directly or with a demux in some cases.
    Or, did it come from a camera/camcorder? Or is it something you downloaded?
    Use Mediainfo and tell us what you've got. Xvid is not what you want for import to Vegas.
    http://www.kiva.org/about
  5. Originally Posted by edDV View Post
    Well, I downloaded the files from the internet. And often, when you download TS files from the net, it contains a lot of errors and stuff. I can't use mediainfo because I deleted the files since I didn't think it was possible to deal with.
  6. Member edDV's Avatar
    Mar 2004
    Downloaded TS files could be from many sources such as digital TV tuners, camcorders or other. I see no reason why they should contain "lots of errors". It is easier to capture these files than play them, particularly if h.264.
  7. Originally Posted by edDV View Post
    Ok, so my main question is then: How do I convert from Divx to AVI settings without getting the error in VirtualDub?
  8. Member edDV's Avatar
    Mar 2004
    So you are sure this is divx?
    Install the divx codec. Decompress the the input and output in a format Vegas will accept.
  9. Originally Posted by edDV View Post
    I already have the Divx codec. The file is a TS file. I use Divx to AVI as a setting in StaxRip, and it wouldn't work, because of the error in VirtualDub. How do I fix this?
  10. Originally Posted by SoccerLover View Post
    The error is named like this: ''Video compression error: The source image format is not acceptable. (error code -2)
    Here is a mediainfo scan on my new TS file:
    General
    Complete name : C:\Users\Bruker\Downloads\Real Madrid - Milan 19.10.2010.ts
    Format : MPEG-TS
    File size : 6.89 GiB
    Duration : 1h 35mn
    Overall bit rate : 10.3 Mbps
    Video
    Menu ID : 11025 (0x2B11)
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : 27
    Duration : 1h 35mn
    Bit rate : 9 432 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Bits/(Pixel*Frame) : 0.182
    Stream size : 6.29 GiB (91%)
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 6
    Duration : 1h 35mn
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Video delay : 4ms
    Stream size : 131 MiB (2%)
    Language : std
    Language, more info : Clean effects
    Audio #2
    Format : AC-3
    Codec ID : 6
    Duration : 1h 35mn
    Bit rate : 192 Kbps
    Bit depth : 16 bits
    Video delay : 18ms
    Language : std
    Hope this can solve the problem, please help fast because I need to make a new video.
  11. open it in tsmuxer and select output m2ts muxing, press start muxing
    this will re-wrap into m2ts and vegas should accept it
    this is better than converting to some lossy format, you keep the original quality
    if you wanted to convert it, you need to install haali media splitter, ffdshow
  12. Member edDV's Avatar
    Mar 2004
    Your TS file is AVC not MPeg2. As poisondeathray says, the issue with Vegas Pro 9 is the wrapper, not the video codec. You should experiment with different containers with tsmuxer as suggested. This will not degrade video or audio quality. If Vegas rejects the 2 channel AC3 audio, you can easily convert audio to PCM stereo without affecting video.
  13. Originally Posted by edDV View Post
    I think the tsMuxer worked actually. YES! Now, can I use this tsMuxer to convert MKV HD files to another file without losing qualtiy? Thank you for all the help given in this thread!
  14. Member edDV's Avatar
    Mar 2004
    Changing the wrapper does not alter quality.
  15. Changing the wrapper does not alter quality.[/QUOTE]
    Ok, so what's that supposed to mean? I'm not a total video genius, so if you could explain yourself...
  16. Member edDV's Avatar
    Mar 2004
    First you have individual audio or video streams encoded by a codec (e.g. MPeg2, h.264, xvid, AC3, MP2... etc.).
    These are multiplexed into various containers (AVI, MPeg2, MP4, MKV, TS, M2T, M2TS ..., etc).
    You can demux the internal streams from the container and remux into a different container without recode. That is basically what tsmuxer does.
    TS containers (TS, MTS, M2T, etc.) are so called linear packetized streams (analogous to robust shipping containers) intended for media recording, network streaming or broadcast. M2TS is a random access version used in flash memory applications and Blu-Ray.
    http://en.wikipedia.org/wiki/MPEG_transport_stream
    See also
    http://en.wikipedia.org/wiki/Elementary_stream
    http://en.wikipedia.org/wiki/Packetized_Elementary_Stream
    http://en.wikipedia.org/wiki/MPEG_program_stream
    http://en.wikipedia.org/wiki/M2ts
    Think of it this way
    Elementary stream is like a birthday gift or card.
    Packetized elementary stream is like a wrapped gift or card in envelope.
    Program stream is a shipping box containing several wrapped gifts and cards.
    Transport stream is a group of hardened shipping containers containing many boxes intended for long distance transport to a particular addess. These may arrive in random order so need consolidation (buffering) at the receiving dock.
  17. Originally Posted by edDV View Post
    See also
    [URL]http://en.wikipedia.org/wiki/M2ts[/UR
    [Attachment 3926 - Click to enlarge]
    Thank you for the useful information!
  18. Hey guyz. Got some bad news. I currently have a new TS file, and I muxed it with tsmuxer. It won't import to Vegas! I'm back where I started. I converted to every single thing the tsmuxer had, and it wouldn't imort. Then I tried Handbrake, but then it made a m4v file that Vegas doesn't recognise. Looks like I'm back where I freaking started...
  19. what kind of ts file? again, use mediainfo...
  20. Originally Posted by poisondeathray View Post
    Ok, sorry for not doing that, forgot it!
    Here you go:
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 8.62 GiB
    Duration : 1h 45mn
    Overall bit rate : 11.7 Mbps
    Maximum Overall bit rate : 35.5 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.0
    Format settings, GOP : M=1, N=48
    Codec ID : 27
    Duration : 1h 45mn
    Bit rate mode : Variable
    Bit rate : 10.7 Mbps
    Maximum bit rate : 40.0 Mbps
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.206
    Stream size : 7.86 GiB (91%)
    Audio #1
    Menu ID : 1 (0x1)
    Format : AC-3
    Codec ID : 129
    Duration : 1h 45mn
    Bit rate : 192 Kbps
    Bit depth : 16 bits
    Video delay : 2ms
    Stream size : 145 MiB (2%)
    Language : Spanish
    Audio #2
    Menu ID : 1 (0x1)
    Format : AC-3
    Codec ID : 129
    Duration : 1h 45mn
    Bit rate : 192 Kbps
    Bit depth : 16 bits
    Video delay : 6ms
    Language : dos
    Audio #3
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Mode : Joint stereo
    Codec ID : 4
    Duration : 1h 45mn
    Bit rate : 160 Kbps
    Video delay : 22ms
    Stream size : 121 MiB (1%)
    Language : tre
    It says Blu-Ray because I used TSmuxer to mux it.
  21. can you cut a small sample with tsmuxer (split&cut tab) and upload it to the site or a free hosting site (e.g. mediafire.com) or here if < 30MB
    You can always convert it with avisynth & vdub into uncompressed AVI for import as well .
  22. No, can't upload a sample of the video. StaxRip is a excellent tool, but it's the VirtualDub that won't let me convert...
  23. yes it will, if you use avisynth to load it into vdub
  24. I don't know how to use AviSynth. I use StaxRip, and choose Divx to AVI. It loads, and then the common error that everybody haves pops up. ''The Source Image'' something like that...
  25. That's too bad, you can learn if you want
    You can basically load anything with avisynth. If a video plays properly you can use an avs script
    You can even load .avs scripts directly into vegas with avfs without intermediate files
    Regarding the error message, post the full message.
    Do you have haali media splitter installed and ffdshow
  26. Originally Posted by poisondeathray View Post
    Ok, so nothing of what everybody has said is working. I am just going to convert the files with Xilisoft Video Converter 5 even if it loses quality. Can't find ANY solutin to this problem... Ridicoulus!
  27. did you try avisynth? if the file plays, you can frameserve it so no quality loss, no time wasted converting
    there might be other ways, but I need a sample
    good luck
  28. Originally Posted by poisondeathray View Post
    good luck
    I've never worked with avisynth before. Do you have any youtube tutorials or any idea? Could you please please write how to do it and stuff?
    -thank in advance
  29. avisynth
    http://avisynth.org/mediawiki/Main_Page
    http://avisynth.org/mediawiki/Main_Page#New_to_AviSynth_-_start_here
    avfs (avisynth virtual file system)
    http://forum.doom9.org/showthread.php?t=133313
    1) Make sure haali media spliter and ffdshow are installed. On win7 use win7dsfiltertweaker to make sure ffdshow is used instead of microsoft decoder .
    https://www.videohelp.com/tools/Preferred_Filter_Tweaker
    2) Create an avs script and mount the image with avfs , import into vegas
    e.g
    DirectShowSource("video.ts")
    ConvertToRGB24(matrix="rec709", interlaced=true)
    Alternatively, you can use a similar script to import into vdub to encode to a lossless intermediate (e.g. uncompressed, lagarith huffyuv, ut video codec , etc...)
    e.g.
  30. Originally Posted by poisondeathray View Post
    avisynth
    e.g
    Ok, so I tried avisynth. I installed it and made a txt. document file and wrote where my file was path and everything, and added the extension .avi to the end(even though it is .ts). It didn't work in Vegas, it just popped up that an error occured. Then I changed the extension to .ts and it didn't work either . What shall I do to make it work?
    e.g.
