What settings would you suggest. That was originally DV-PAL. The clip was saved as .mov but it looks the same.
Results 31 to 34 of 34
What settings would you suggest? It was in DV-PAL. That was .mov but it looked the same.
I don't use a Mac and I don't know anything about the hardware and software you are using. But generally you should set the capture software to capture VHS at 720x576, 4:3, YUY2, interlaced, with no cropping or resizing. Maybe if you posted some sample images of the config dialogs I could give you more specific suggestions.
funny, there is exactly the same concern in another opened topic
(aka fields corruption)
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 10:02 -
horizontal lines in x264 encoded dvd using MeGUI
By codemaster in forum DVD RippingReplies: 5Last Post: 9th Dec 2010, 06:48 -
horizontal lines in mpeg2
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2008, 17:05 -
Premiere AVI to Encore to DVD - combing/horizontal lines on TV
By spicediver10191 in forum Video ConversionReplies: 0Last Post: 14th Nov 2007, 07:18 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 12:06
