Results 1 to 10 of 10
  1. Member Deter's Avatar
    Dec 2007
    Hi,
    Just a few questions about VirtualDub
    Currently filtering mpeg2 files, would like to use some of the VD filters to fix errors in the video. However can't edit like 2 hour videos cause I run out of room on my PC. Would like to make smaller output files, basically want to take the filtered file and issue back to DVD.
    The next problem when I create these massive AVI files they have bad interlacing issues, would like the output file to have the same interlacing as the DVD or mpeg2 file.
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    http://www.virtualdub.org/
    http://forums.virtualdub.org/
    USA
    The first problem you could get around by frameserving the VD edited/filtered video directly to a MPEG encoder, then you wouldn't have a in-between edited file taking up hard drive space. https://www.videohelp.com/oldguides/virtualdubframeserve
    The second part: Don't deinterlace.
    Dec 2005
    Canada
    If you intend the final format to be AVI, under 'Video', choose 'Compression' and select a codec else the output is uncompressed..
  5. If you can't frameserve, install HuffYUV or Lagarith to get you lossless compression. That should shrink your intermediate files to about 1/3 to 1/4 the uncompressed size. HuffYUV is faster but doesn't compress as much. Lagarith compresses more but isn't as fast.
  6. Member Deter's Avatar
    Dec 2007
    Downloaded HuffYUV, now how do u install it in to VD and how do u set up your output files to this source.
  7. Extract the files to a suitable location -- like the Desktop. Right click on the INF file and select Install. The DLL is copied to where it needs to be and registered with the system. You can then delete the files on the Desktop (or wherever).
    If you are running 64 bit Windows the procedure may be a little different.
  8. Member Deter's Avatar
    Dec 2007
    Yep 64 Vista......
  9. If you are running the 64 bit version of VirtualDub be sure to get a 64 bit version of HuffYUV. Under 64 bit Windows 64 bit programs require 64 bit codecs, 32 bit programs require 32 bit codecs.
    When running 32 bit VirtualDub and installing 32 bit HuffYUV under 64 bit Windows you need a special installation procedure:
    https://forum.videohelp.com/threads/271712-Lame-MP3-Encoder-on-Vista-x64#1723154
  10. Member Deter's Avatar
    Dec 2007
    Lagarith seemed to install fine, so testing out a 50 minute video, report back when it is done...
