    Sep 2006
    I have several videos that won't play on my xbox360, they're old and apparently Divx3 videos. I tried to open one of the videos in MPEG4 Modifier to check the header code, and it wouldn't open. It gave me the error message "invalid mpeg-4 video, (startcode not found at beginning of frame.)
    I demuxed it with My MP4Box GUI and it spat out .div3 and .mp3 files. However it wouldn't remux these two files as an mp4 apparently being unable to read the .div3 video file.
    I also tried filtering the video through virtualdub (this usually rewrites the header and solves any such problems) but this didn't fix the problem.
    Here's the mediainfo log:
    Format : AVI
    File size : 688 MiB
    Duration : 1h 49mn
    Overall bit rate : 874 Kbps
    Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
    Writing library : VirtualDubMod build 2366/release
    Video
    Format : MPEG-4 Visual
    Codec ID : DIV3
    Codec ID/Hint : DivX 3 Low
    Duration : 1h 49mn
    Bit rate : 753 Kbps
    Width : 656 pixels
    Height : 384 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.125
    Stream size : 592 MiB (86%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1h 49mn
    Bit rate mode : Constant
    Bit rate : 112 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 88.1 MiB (13%)
    Alignment : Split accross interleaves
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
    do u teevee?
  2. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    https://forum.videohelp.com/threads/269851-DivX3-to-DivX6 basically, divx 3 was not mpeg-4 complaint and reccomended you had divx 4 and 3 installed concurrenty back in the day. so you need to install ffdshow or divx 3 and recode it to another format. If possible get the source and make a new enocde
    if all else fails read the manual
    Aug 2008
    Canada
    This should do it:
    https://forum.videohelp.com/threads/285664-DIVX-3-to-DIVX5?p=1727268&viewfull=1#post1727268
    You may want to have it convert the audio as well, as 112kps is not standard. The utility in the link will re-encode it at 128kps
  4. DECEASED
    Jun 2009
    Heaven
    lame.exe --longhelp says:
    MPEG-1   layer III sample frequencies (kHz):  32  48  44.1
    bitrates (kbps): 32 40 48 56 64 80 96 112 128 160 192 224 256 320
    MPEG-2   layer III sample frequencies (kHz):  16  24  22.05
    bitrates (kbps):  8 16 24 32 40 48 56 64 80 96 112 128 144 160
    MPEG-2.5 layer III sample frequencies (kHz):   8  12  11.025
    Aug 2008
    Canada
    You are correct. However, many hardware players have problems playing back MP3 audio that is has a bitrate less than 128K I know that my LG DVD player (w/ Divx compatibility), Dlink DSM-320, and Popcornhour don't seem to like bitrates lower than 128K.
