I have a DivX3 video file and want to convert it to DivX6 without any loss in quality.
What is the best way to convert the file?
Easy enough to convert. You could use VirtualDub Mod (or VD). You may need the Divx3 codec to open it. But the output file will likely be much bigger. You can't do much of any conversion with no loss in quality, you can only minimize the loss. Try a short representative clip and check the output quality. Better quality=higher bitrate=bigger filesize.
You will also need the Divx6 codec installed. Or use the freeware Xvid codec. With Xvid you can use a Quantizer setting of 2 and you should have fairly close quality.
I prefer VD Mod myself. Lots of guides available to the bottom of the VD toolpages. Use full video processing and the select your output codec. If the audio is OK, it will just add it to the encoded file.
DivX3 Problems
By Startropic1 in forum Video ConversionReplies: 4Last Post: 13th Jul 2010, 07:58 -
converting hd sources to .avi - xvid or divx6/7 ?
By uk_dan2k in forum Video ConversionReplies: 3Last Post: 23rd Apr 2010, 09:11 -
Is it possible to use xVid to decode Divx3?
By cheerful in forum Software PlayingReplies: 0Last Post: 10th Feb 2010, 13:35 -
divx6 ac3 to hdtv
By makapa in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2008, 13:53 -
Subtitles in DivX6
By nowhere in forum EditingReplies: 0Last Post: 20th May 2007, 10:42
