Results 1 to 14 of 14
    Dec 2009
    The M2V video I am trying to get on DVD via AVStoDVD does not work anymore and I dont know why.
    My logfile representing a typical run is seen below. When I hit the Start button, the HCenc 0.23 window pops up. The HCenc window processing values are filled in except under the encoding statistics pass1 section. The software seems to freeze from there. I end up having to abort the program.
    It is interesting I am able to use SUPER to convert this to AVI without problems and them use AVStoDVD to convert the AVI to the DVD video structure. After that I can burn with a different utility but would prefur to have the AVI step with SUPER taken out.
    Another thing I have tried is changing the TITLE>EDIT TITLE tabVIDEO section value from HCenc OPV 1-pass to HCenc VBR 2-pass with the same results.
    I have also tried to change the audio output format setting in TITLE>EDIT TITLE Audio tab to AC3 since DTS audio is not encoding supported. When I do this the processing is then halted telling me to look in the log file. The log file looks identical except for the appending of this text at the bottom of the file:
    Ideas Anyone?
    TIA
    <5/27/2010 4:08:32 PM>
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: QuEnc CBR 1-pass
    Target Video FileSize: 4060.7 MB
    QuEnc Parameters: -i "C:\Temp\Junk\DVD_1_Columbia1992.avs" -o "C:\Temp\DVD_1_Columbia1992.m2v" -b 6120 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
    Here is the original Log file:
    <5/27/2010 4:02:26 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Temp
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    AVS Source Filter: A2DSource
    AVS Resize Filter: Spline16Resize
    Video Resolution: 0
    Video BitRate Min: 3000
    Video BitRate Level 1: 6000
    Video Profile Level 2: 4500
    Video BitRate Max: 9000
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    DVD Audio Format: 0
    DVD Audio BitRate: 128
    Keep DVD Compliat Audio: 1
    Normalize Audio: 1
    DVD Audio Language: EN - English
    DVD Subs Language: EN - English
    Chapthers Interval: 10
    Use Source Chapters: 1
    DVD Burning Drive: E: Optiarc DVD RW AD-7240S 1.03
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    TITLE 1 SOURCE FILES
    Video: C:\Temp\Columbia1992.mkv
    Info: AVC - 5105 kbps - 1280x544 - DAR 2.353 - 23.976 fps (CFR) - Progressive - 1:32:40 hours - 133462 frames
    Audio: C:\Temp\Columbia1992.mkv
    Info: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 1:32:46 hours
    Subs:
    [MediaInfoLib - v0.7.26]
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Temp\Columbia1992.mkv", CacheFolder = "C:\Temp\Junk")
    # Audio is frameserved by AviSynth just for Preview and Edit purposes.
    Audio = A2DAudioSource("C:\Temp\Columbia1992.mkv", CacheFolder = "C:\Temp\Junk")
    Video = Video.ConvertToYV12
    #Using DGPulldown to upsize FPS
    Video = Video.AddBorders(0,88,0,88)
    Video = Video.Spline16Resize(720,480)
    AudioDub(Video, Audio)
  2. Hi ehunter,
    there's something missing: you said that you have tried with both HCenc 2-pass and HCenc 1-pass, but the log file shows that QuEnc 1-pass was used instead.
    BTW, if the encoder program is hanging, please be patient a little bit (max 2 minutes): sometimes file indexing is required, and it takes some time.
    Moreover, be sure to use latest AVStoDVD release (2.3.0) and that all required software is installed (Haali Media Splitter, good directshow codecs as ffdshow).
    Let me know
    Bye
    MrC
    AVStoDVD Homepage
    Dec 2009
    Sorry for the confusion. I have tried all three encoders and, in my haste, mismatched my description with the log file I posted.
    Last night I noticed the newer version, V2.3.0. I uninstalled the old, installed the new, set a few necessary processing options, and have rerun the software. Here is the logfile I am presently receiving. I noticed a new logfile for the encoder so that is posted following this logfile.
    This has been running for 9 hours now. The software is waiting for something and I cant figure out what it is. My next post you will see a screenshot of the HCenc 0.24 processing screen. In the upper right you can see how the process is IDLE. I speculate it is that way for 99% of the time. After over 9 hours it has been able to plod its way to 20% in progress.
    I have a I7/860 (8virt cpus) and usually these runs average less than 30min. Is there something else you would like me to recheck? In looking at the logfile I see I forgot to change to NTSC but that should not matter.
    <5/27/2010 11:08:26 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: PAL
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Users\Eric\Documents
    PREFERENCES
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6500
    Video BitRate Max: 8500
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Chapters Interval: 5
    Save Log file: 1
    Info: AVC - 5236 kbps - 1280x544 - DAR 2.353 - 23.976 fps (CFR) - Progressive - 1:32:46 hours - 133462 frames
    Audio 1: C:\Temp\Columbia1992.mkv
    Info: DTS - 1536 kbps - CBR - 6ch - 48000Hz - 24bit - 1:32:46 hours - Internal
    Subs:
    [MediaInfoLib - v0.7.32]
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Temp\Columbia1992.mkv", CacheFolder = "C:\Users\Eric\AppData\Local\Temp")
    Audio = A2DAudioSource("C:\Temp\Columbia1992.mkv", CacheFolder = "C:\Users\Eric\AppData\Local\Temp")
    #Using DGPulldown/HCenc to upsize FPS
    Video = Video.Spline64Resize(720,576)
    Encoding Profile: HCenc VBR 1-pass
    HCenc Parameters: -ini "C:\Temp\Junk\DVD_0_Columbia1992.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Temp\Junk\DVD_0_Columbia1992_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Eric\Documents\DVD_0_Columbia1992.m2v
    *LOGFILE C:\Temp\Junk\DVD_0_Columbia1992.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 6120
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 60
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    | HCenc - MPEG2 encoder - rel. 0.24.0 |
    MPEG profile@level: MP@ML
    input: C:\Temp\Junk\DVD_0_Columbia1992_1.avs
    output: C:\Users\Eric\Documents\DVD_0_Columbia1992.m2v
    | encoder settings |
    profile: BEST
    frames: 0 - 133462
    framerate: 23.976
    aspect ratio: 16:9
    chroma format: 4:2:0
    bitrate Kb/s: 6120
    max. bitrate Kb/s: 9000
    pass: 1 (VBR)
    pulldown: no
    closed gops: no
    VBV check: yes
    scene change det: yes
    interlaced: no, TFF
    goplen,B-pic: AUTO
    dc_precision: 10
    intraVLC: auto
    scan method: zigzag
    bias: 60
    chapter frames: 0
    time code: 0 0 0 0
    CPU: SSE4 (4.2)
    priority: idle
    SMP active: yes
    matrix: MPEG, adaptive
    luminance gain: yes, level 1
    adaptive quantization: yes, strength 1
    deadzone quantization: auto
    | source stats |
    nr. of frames in source: 133463
    width*height: 720x576
    fps: 23.976
    nr. of frames to encode: 133463
    frames to encode: 0 – 133462
    Dec 2009
    I just noticed a message on the HCenc 0.24 window. The message says:
    Very Low Qualtizer, Bad Q Estimation, Please re-consider settings.
    What do I do to compensate for this? Job has been running 4 days already. (Had to restart)
    Originally Posted by _MrC_ View Post
    Hi ehunter,
    Let me know
    Bye
  5. Hi ehunter,
    I must say that your patience is really huge and deserving respect! Wow, 4 days waiting! Ok, there's surely something wrong. Let's deepen:
    1. Have you installed Haali Media Splitter (it comes with AVStoDVD installer)?
    2. Have you installed a good directshow codecs suite (ffdshow)?
    3. Are you running Windows 7? If yes, have a look at AVStoDVD Help/FAQ/General/Q1.5
    4. HCenc msg is just a warning, surely not the cause to the current problem.
    Let me know
    MrC
    MrC
    AVStoDVD Homepage
    Dec 2009
    When I installed the newest AVStoDVD I removed the old one first.
    1)
    Then I downloaded the latest version from https://www.videohelp.com/download/AVStoDVD_230_Install.exe
    I then ran the installer. A screen poped up asking which components to Install. I selected AviSynth 2.5.8,
    ImgBurn 2.5.1.0, Haali Media Splitter 1.10.120.15 and Active X Controls even though the instructions say
    since they are unchecked, they are already installed. I checked these "on" just to make sure .
    The step for installing the Haali Splitter had some setup options with checkboxes. I left everything
    at the default. (Disable MPC internal Matroska Splitter (checked), Disable Gabest internal Matroska
    Splitter (checked), Enable MP4 Support (checked), Enable OGG/OGM support (checked), and Enable MPRG-TS Support
    (checked). Two items were not checked and I left them that way. They are Enable Avi support and Enable
    MPEG-PS support. Then the install completed.
    2)I was not sure about ffdshow so I followed the link and re-installed that too, version 8.1.
    There were also some configuration options that popped up. I expanded on the instalation options
    just to make sure everything got overwritten and I included other options that looked available.
    3)Yes, I am running Win7 Pro64 with all the latest patches so I looked at the Help/FAQ/General/Q1.5 you
    mentioned. I downloaded and installed the Preferred Filter Tweaker (V3.2 May 6, 2010). I used the
    program to change everything to FFDSHOW. Hopefully I did not miss anything.
    I will try to use the program now. I have aborted the run that has been going for many days aleady.
    I will report back.
    Dec 2009
    Thanks very much for the Help
    Everything seems to work now
    I should have reinstalled the components in parts so I could determine which was the problemed area. I
    ended up installing everything all at once and just testing to see if it works.
    63 minutes for a 4.6GB 1280x544 MKV video into standard DVD structure.
  8. I’m really hoping someone can help me out here!
    I’m having the same problem and have no idea what is wrong.
    I’m in process of making 4 DVDs using AVStoDVD. The first 2 encoded in a little over 4 hours. I’m on the third, and it has been running now for 9 hours in HCenc and is only at 97% of the FIRST 8-min. title of 11. At this rate, it will take 5 days, but it seems to be progressing slower and slower as it goes… I need these DVDs by the 26ᵗʰ (9 days from now) and still have one to do after this.
    The only difference between this one and the first 2 I did is that the file types for the videos are .mov rather than .mp4. The 4ᵗʰ and final DVD after this are .mov files too so I suspect I will have the same issue.
    I too have the warning “very low Quantizer, bad Q estimation, please reconsider settings”, but I’ve read in several places, including here, that it’s not an issue and to just ignore it.
    I’m using my Mom’s computer to do this. It’s Windows Vista (rest of computer specs are in my profile). It’s all I have right now as I’m over 461¼ miles from my own until at least the end of June and need this before then. It worked fine for the 1ˢᵗ 2 DVDs.
    Any ideas? I too installed everything I believe (on May 8, so versions are current). Should I uninstall and reinstall everything from scratch like that^ guy did? Think that would help? Or are there any settings I can adjust to speed things-up so this disc doesn’t take a week or more to complete?
    Thanks a ton in advance to anyone out there who can help me,
    UPDATE: Title 1 of 11 has now finished, took 9 hrs., 36 min., & 23 sec.. On Title 2 now. Entire project is now 4% complete.
    Watch, when this finally finishes a week from now, the DVD probably won‘t even work after all this. XD
    Mar 2008
    Post the AVStoDVD log from this run, it may provide some clues.
    What version of Windows are you using? What is your PC specification, most important CPU and RAM.
    I can typically encode a 2 hour movie, 2-pass, in about 70 minutes on my very modest AMD FX 4300 with 4GB RAM
    Secondly you should have started a new thread. Re-opening such old threads is frowned upon...
  10. Originally Posted by davexnet View Post
    Sorry about that!!
    PC Specs:
    Windows: Vista Home Premium 6.0, Build 6002, Service-pack 2
    CPU: AMD Phenom X4 9650 (Quad-core), 2.3 GHz
    RAM: 4 GB
    Log file so far:
    <2017 05 17 2:09:37 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Titles number: 11
    DVD Size: 4449/4450 MB (100%)
    DVD Label: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
    DVD Menu: Motion Menu
    Output Folder: C:\Users\John\Videos
    Delete Temp Assets Files: No
    Delete Temp Working Files: Yes
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: A2DSource
    AVS Audio Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
    Frame Adjust Strategy: 0
    FPS Hard Conversion: 0
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 0
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): EN - English
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 16pt (255,255,255)
    DVD Burning Drive: E: PIONEER BD-ROM  BDC-202 1.01
    Execute with Elevated Privileges: 0
    Unload ActiveMovie Library: 1
    Adjust DirectShow Filters at runtime: 1
    Save General Settings: 0
    SYSTEM INFO
    Processor Name: AMD Phenom(tm) 9650 Quad-Core Processor
    Operating System: Windows Vista - Service Pack 2 (6.0.6002) 64 bit
    User has Admin Rights: YES
    Running with Elevated Privileges: NO (3)
    Available Output Disc Space: 6 GB
    AviSynth is installed: YES (release 2.6.0)
    LAV Filters is installed: YES (release 0.69.0)
    ffdshow is installed: NO
    Video: D:\Jen's Videos\Downloads\▓▓▓▓\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.mov
    Info: AVC - 444 kbps - 640x360 - DAR 16:9 - 24.872 fps (VFR) - Progressive - 8:52 minutes - 13240 frames
    Audio 1: D:\Jen's Videos\Downloads\▓▓▓▓\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.mov
    Info: AAC LC - 96 kbps - VBR - 2 ch - 44100 Hz - 8:52 minutes (0 ms delay)
    [MediaInfoLib - v0.7.77]
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\MotionProtectedFPS.avsi")
    Video = A2DVideoSource("D:\Jen's Videos\Downloads\▓▓▓▓\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.mov", CacheFolder="C:\Users\John\AppData\Local\Temp", VFR=true, FrameRateNum=3109, FrameRateDen=125, FrameRate=24.872)
    Audio = A2DAudioSource("D:\Jen's Videos\Downloads\▓▓▓▓\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.mov", CacheFolder="C:\Users\John\AppData\Local\Temp")
    Video = Video.ConvertToYV12()
    Video = Video.Lanczos4Resize(720,480)
    Video = Video.MotionProtectedFPS(29.97)
    Audio = Audio.SSRC(48000)
    DIRECTSHOW AUDIO MIXER OPERATIONS:
    No LAV Filters mixer ON/OFF adjustment required at runtime
    Video Encoding Profile: HCenc VBR 1-pass
    Target Video FileSize: 388.4 MB
    Encoding Parameters: -ini "C:\Users\John\AppData\Local\Temp\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\John\AppData\Local\Temp\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_1.avs
    *AVSRELOAD
    *OUTFILE D:\Jen's Videos\Downloads\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.m2v
    *LOGFILE C:\Users\John\AppData\Local\Temp\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 6125
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 60
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *DBPATH  C:\Users\John\AppData\Local\Temp
    *WAIT 2
    <2017 05 17 11:53:12 AM>
    END VIDEO ENCODING OPERATIONS
    Video Source Filter: A2DSource (FFmpegSource2 (cache off))
    Created File: D:\Jen's Videos\Downloads\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.m2v (386.5 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 6091 kbps - 720x480 - DAR 16:9 - 29.97 fps - Progressive (TFF) - 8:52 minutes - 15952 frames
    START AUDIO ENCODING OPERATIONS (Track 1)
    Wavi+Aften Parameters: "C:\Users\John\AppData\Local\Temp\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "D:\Jen's Videos\Downloads\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_1.ac3"
    <2017 05 17 11:54:13 AM>
    END AUDIO ENCODING OPERATIONS (Track 1)
    Audio Source Filter: A2DSource (FFmpegSource2 (cache off))
    Created File: D:\Jen's Videos\Downloads\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_1.ac3 (12.2 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 8:52 minutes (0 ms delay)
    DVD CHAPTERS CREATION OPERATIONS
    Title 1 Input Chapters List: 8991
    Title 1 Output Chapters List: 8991
    Created File: D:\Jen's Videos\Downloads\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_01_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Chapters.txt (8 Byte)
    TITLE 2 SOURCE FILES
    Video: D:\Jen's Videos\Downloads\▓▓▓▓\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.mov
    Info: AVC - 491 kbps - 640x360 - DAR 16:9 - 24.868 fps (VFR) - Progressive - 8:49 minutes - 13145 frames
    Audio 1: D:\Jen's Videos\Downloads\▓▓▓▓\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.mov
    Info: AAC LC - 96 kbps - VBR - 2 ch - 44100 Hz - 8:49 minutes (0 ms delay)
    AVISYNTH SCRIPT
    Video = A2DVideoSource("D:\Jen's Videos\Downloads\▓▓▓▓\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.mov", CacheFolder="C:\Users\John\AppData\Local\Temp", VFR=true, FrameRateNum=6217, FrameRateDen=250, FrameRate=24.868)
    Audio = A2DAudioSource("D:\Jen's Videos\Downloads\▓▓▓▓\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.mov", CacheFolder="C:\Users\John\AppData\Local\Temp")
    Target Video FileSize: 386.3 MB
    Encoding Parameters: -ini "C:\Users\John\AppData\Local\Temp\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_02_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\John\AppData\Local\Temp\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_02_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_1.avs
    *AVSRELOAD
    *OUTFILE D:\Jen's Videos\Downloads\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_02_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.m2v
    *LOGFILE C:\Users\John\AppData\Local\Temp\▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓_Title_02_▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 6125
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 60
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    Thanks for helping
  11. I actually I’m seeing now in the log file that it says ffdshow is not installed. Is that the issue?
    EDIT: I’m also noticing that it says the output disc space is only 6 GB, which is what’s free on the C:\ drive, but I thought I had made the target the D: where there is plenty of room.
    Maybe this is the problem too. ugh, I don’t think there’s any way to change that without starting the whole project over and redoing the carefully placed menu I made from scratch.
    Mar 2008
    Which version of AVStoDVD is this? I am unable to see the version since this is not a complete log.
    I would update to the latest (version 2.86 download it from this site)
    In the Preferences/Avisynth tab, change "hard framerate conversion" from Motionprotected to ChangeFPS and save the preferences
    as default.
    Then re-add your files and recreate the project.
    You can check the Avisynth tab at "view/edit title settings", you should see
    Video = Video.ChangeFPS(29.97) instead of Video = Video.MotionProtectedFPS(29.97)
    Once this is confirmed you can retry the project.
    Regarding this:
    It is a message warning you that the bitrate is too high for the material. This can be resolved by lowering the bitrate
    at title edit/video tab try somewhere about 20%. For example if the bitrate is 6000 , lower it to 4800
    or you can use a better matrix. At "HCenc advanced options" change the matrix to FOX2 .
    I would try changing the matrix first.
    If you still see that message after changing the matrix, then you'll have to lower the bitrate also as above
    For both of these "tweaks" you should do it for each title in the project by using prev title/next title buttons
    EDIT saw your update regarding disk space.
    In Preferences on the paths tab, change "DVD output" to the drive with more space. Select save as default and exit out.
  13. Originally Posted by davexnet View Post
    The version is in fact 2.8.6 from Apr. 8 /17, which I installed from SourceForge.net on May 8.
    Thanks for all these suggestions. Stopped the process after 11½ hours (still on Title 2) – I will try them and report back
  14. Originally Posted by davexnet View Post
    as default.
    Regarding this:
    Worked like a charm – Thank you!
    And with no difference in quality in end-product… It somehow looks even better on TV than it did on computer!
    Whole thing was done in 1 hr., 20 min., 42 sec. — MUCH better!
    Changing to the FOX2 matrix for each track worked to get rid of that Quantizer warning message without needing any further bitrate adjustments.
    You know your stuff. I never would’ve figured any of this out myself. I appreciate your help so much!
    Sorry again for resurrecting this old thread. I should’ve started a new one and linked to it if need-be.
    <!-- NO ONE ELSE RESPOND -->
