VOB2MPG has been working OK. today I tried to start it up and got the shortcut message "error wrong parameter"
so I went into PROGRAMS and started it from there and got this error message
Version: VOB2MPG PRO
Build: 3.0.0520
Type: System.Runtime.InteropServices.COMException
Source: System.Windows.Forms
Message: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
InnerException:
StackTrace: at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithoutLicense(G uid clsid)
at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license, Guid clsid)
at System.Windows.Forms.AxHost.CreateInstanceCore(Gui d clsid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at VOB2MPG_PRO.xfed3de3bc2a8e64d.x85601834555fb7d5()
at VOB2MPG_PRO.xfed3de3bc2a8e64d..ctor(String[] args)
at VOB2MPG_PRO.x867eb3246b182488.xc447809891322395(St ring[] xce8d8c7e3c2c2426)
As this means nothing to me I thought I better ask and if I have to erase it and reload how do I keep my registration.
les972
it is quite strange with PRO version.
Build: 3.0.0520
I tried free VOB2MPG, it crashed as well and did not serve the purpose.
Asking for update to PRO. However I use virtualdub now.Last edited by Bonie81; 18th May 2010 at 20:18. Reason: typo
Hi ChrissyBoy. Yes that was the one of the first things that I did but it was and is still the same. The thing that annoys me the most is the fact that they can't even be bothered to give any technical backup. It's a case of "you spend your money with us ,now sod off". I hate that sort of attitude
les972 -
By "them/they" you mean me. So rather than getting to the bottom of your issue and resolving it as I do normally - I will refund your purchase.
Hi ChrissyBoy Thank you for your reply to my message. I should like to apologise if I upset you but unfortunately there is no way for me to know that you are the force behind the program, as far as I was aware you are like me just a user of the program. Right let me say that I have used the program once and found it did what it was supposed to do so no problems there but since I purchased that's when the problem started. The free version still works OK and it looked as if no one involved with the program was interested in solving the problem.So knowing what I know now I will hold my hand up and say sorry for jumping feet first. Please don't refund the money just help me with the problem as I have relations bringing me their videos to convert to DVD and I think your program is most likely the best for that job
les972
VOB2MPG Pro is not working for me
By BKKiran in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Feb 2012, 15:58 -
Vob2MPG Pro - stopped working
By Mudmover in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Feb 2011, 02:34 -
Video preview not working in VOB2MPG PRO new build 3.0.0700
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th May 2010, 14:44 -
Working with VOB2MPG: speed issue hint
By cdgmol in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 31st Jul 2009, 17:57 -
VOB2MPG not working :(
By singernontechie in forum DVD RippingReplies: 19Last Post: 9th Nov 2007, 12:38
