I was attempting to convert VOB to MPG. After selecting the VOB set and the location to which the MPG would be created, I received the following error information. HELP!
Version: VOB2MPG PRO
Build: 3.0.0700
Type: System.ArgumentOutOfRangeException
Source: mscorlib
Message: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
InnerException:
StackTrace: at System.Collections.CollectionBase.System.Collectio ns.IList.get_Item(Int32 index)
at VOB2MPG_PRO.IFO.xe2e75cd0c88496d4.get_Item(Int32 index)
at VOB2MPG_PRO.IFO.x32eac27632acc346.xc5034730a302ffc e()
at VOB2MPG_PRO.IFO.x32eac27632acc346.xa3a9daebe1fd5c9 3(String xeadccf02f8622700, Boolean xb909d68cec5e9c0b)
at VOB2MPG_PRO.xfed3de3bc2a8e64d.bOpen_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I'm attempting to rip. It's a commercial DVD of my daughter's dance recital.
When we say commercial, we usually mean professionally authored for a studio, and pressed with copy protection. Yes, you paid for yours, making it a commercial enterprise, however it will most likely have been authored with the same tools many of use here, and burned to standard blank DVDs. I have seen some pretty funky structures created by people doing their own authoring and encoding.
I would start by copying the Video_TS folder to your HDD using Windows Explorer. There is no copy protection to stop you doing this. Once there, run it through FixVTS to make sure the structures are sane. Finally, try again with VOB2MPG.Read my blog here.
The disk would not copy to my hard drive. I received the following error. "Cannot copy VTS_3_1: Data Error (Cyclic Redundancy Check)
You could try use a ripper then like dvddecrypter or dvdfabhddecrypter and see how it works.
Sorry for my delay in responding to your direction. I was under a great deal of pressure to finish the task at hand. The dvdfabhddecrypter worked. Thanks for everything, including a quick response.
How can I INDEX a .TS file?
By lovelylisa in forum Video ConversionReplies: 9Last Post: 7th Jun 2011, 15:48 -
To Index or Not?
By ocgw in forum ComputerReplies: 4Last Post: 10th Nov 2009, 07:00 -
Forums index incorrect
By Gavino in forum FeedbackReplies: 1Last Post: 23rd Aug 2009, 04:49 -
Screenshots index like this one, how can I do this?
By miraniec in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2009, 20:26 -
Index the pictures
By stiltman in forum FeedbackReplies: 2Last Post: 21st Nov 2007, 09:09
