About the audios; first open the 2 AVIs in something like GSpot or MediaInfo to confirm they're really in the same format (both MP3 or both AC3, for example). If the only differences are in bitrate (130 and 128, for example), then maybe you can join them. Just not using VDubMod. It's very strict about such things. Instead maybe try AviDemux. Here's Baldrick's guide to using AviDemux:
https://forum.videohelp.com/threads/295782-How-to-get-started-with-avidemux-edit-and-co...y-video-format
Results 31 to 32 of 32
As always, thanks very much for your reply! All the trouble is due to at the conversion I used "VBR MP3" in AutoGK's setting. Although it was supposed to be 128 kbps but the overhead (whatever that means) is different for files converted at different times. So VirtualDubMod refuses to play/join them. I worked around it by using the setting "Auto" for output audio type. Since I'm converting to 100% target quality, the file is big, the output audio is AC3. (I guess choosing "original AC3" should work too.) VirtualDubMod now plays and joins the files like a charm. Thanks again!
Help / 2nd opinion / advice needed from video experts - See attached Images
By sanchopanza in forum Video ConversionReplies: 5Last Post: 18th Mar 2011, 16:22 -
First video on Youtube, I need workflow and format advice
By Arty84 in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2011, 13:43 -
Website design advice (Experts)
By neworldman in forum ComputerReplies: 10Last Post: 17th Jan 2011, 10:16 -
How to add subtitles to a DVD (VOB file) and upload to youtube
By qi99 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 15:46 -
FAVC105 Did Not Add Subtitles To Video
By moviebuff2 in forum SubtitleReplies: 3Last Post: 24th Jan 2008, 03:50
