I have been converting our DVDs for the Wife to watch on long commutes into work, using a PSP.
It was fairly easy to do Subs with DVDFab, XviD4PSP and VSRip using one of Baldricks guides (for which I was very grateful) and I now have Amelie, Inglorious Basterds etc., which is great.
However, there are some like District 9 which seem a bit tricky.
Could any of the more experienced types point me in the direction of the required tools to use, if there is an easy way to do these? Or alternatively, as I am not desperate to do all of our DVDs, tell me whether some are just not worth the effort!
It is probably not worth me spending hours and hours on them, but if there is a fairly easy way I would be grateful to know.
I am not after a step by step guide, just a quick "you need these tools, guides on forum XXX," or "don't bother it's too time consuming" sort of reply.
Many thanks for any replies.
Results 1 to 1 of 1
Angels and Demons Forced Subs
By eon_designs in forum Blu-ray RippingReplies: 3Last Post: 5th Apr 2018, 16:33 -
Forced subs on HD-DVD rip
By jlchavis0844 in forum SubtitleReplies: 6Last Post: 19th May 2010, 07:40 -
Forced Subs WAY Out Of Sync
By Anakin in forum Video ConversionReplies: 8Last Post: 20th Apr 2009, 09:50 -
Forced Subs from Blu-Ray to WMV
By needcert5 in forum Blu-ray RippingReplies: 2Last Post: 5th Dec 2008, 17:31 -
Determine if forced subs are on a DVD
By whatisk in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 18:42
