Is it possible for me to capture my xbox 360 if I connect it via VGA to my GPU and then my GPU to monitor using DVI. If not what are cheapest alternatives?
Results 1 to 15 of 15
NO. VGA capture is not supported by a GPU.
There are inexpensive solutions for SD capture.
For HD resolutions, an alternative is the Hauppauge HD-PVR. See demos on YouTube. You will need to use an analog component loop to an HDTV for gaming.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thanks, can you detail the inexpensive SD solutions and would I still be able to play in HD through my VGA and monitor?
Thank you -
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
The 360 component/composite cable will output both at the same time.
Have a good one,
neomaine
Yes, I'm saying the combination component/composite cable will output on both. Its not what the OP was directly looking for, but just wanted to clarify that there's at least one native way to watch/play in HD and SD simultaneously.
Have a good one,
neomaine
It was with the original 360 that came out. We've been using an Elite the past few years since the original had (surprise) the RROD, and so, been using HDMI since. My son uses the Black Magic Intensity Pro for captures now. Actually the BMIP has a tail for analog captures which include component. If I find some time this weekend I'll see if it still works and verify if its HD or not.
Have a good one,
neomaine
well if its not HD play and SD capture I won't be doing it. Anyway I hope you're right neomaine.
btw my computer specs are Intel Celeron E1400 @ 2.0GHz, 2GB RAM, ATI Radeon HD 4600 all running on Windows 7 -
I'm trying to do the same thing as you, HD play SD record. I was going to do a VGA to a powered VGA splitter then from the splitter to the monitor and my SD recording device. However, I'll need to down convert my HD VGA resolution to SD using a converter. My native res is (1680x1050) the problem you'll encounter here is that there aren't any (save maybe one) that can do 1680x1050 to SD down conversion. Then at that point you're running around $100 in converters plus if you don't already have a SD recorder you'll need one of those which will cost at least another $100. At which point you're up to the price of some HD recording (Black Magic Intensity capture card $200 or so) options. I'm not sure how you'd setup a capture card, I personally would do a VGA split again before sending a signal to my computer. (Because going into and out of computer will have lag for sure)
edit:
However, if you have a lower native resolution than mine you should be able to find a VGA to SD converter that will work. However the whole thing is anything but cheap. -
What? 640x480i? http://en.wikipedia.org/wiki/S-Video The goal is to play in HD using a monitor (via VGA cable) and rec for a reasonable price, so SD is fine, and do all of this without causing the video to have a 'lag-time'.
Anyway I figured out how to do it:
Recording-an-Xbox-360-using-VGA-without-inducing-lag
The above topic will be updated if anything changes. can't guarantee this one....
Summary:
S-Video is interlace PAL (576 lines, 25 fps) or NTSC (480 lines, 29.97 fps).
VGA is progressive analog RGB at various resolutions so let's say 1280x1024 at 60Hz. A typical display card will use the RAMDAC to output the selected resolution to the DB15 connector and will downscale a 640x480 output to the NTSC encoder. Then it will interlace to 480i for Y luminance and and encode an NTSC subcarrier for C. The U and V resolution will be in the 1 MHz range or about 80x480 each. This is why S-Video from a display card looks so crappy for game or computer display.
A VGA to S-Video converter box can go the high road or the low road. The low road would use a cheap A/D and similar RAMDAC components used for display cards. These are very cheap. A high end converter would use a quality A/D on each of RGB, three 1280x1024 memories, high quality H and V scalers to allow up to ~854x480 for wide NTSC or 1024x576 for wide PAL luminance. Then they would interlace and encode an NTSC or PAL subcarrier still with under 1.5 MHz U and V (~120x480 at best) C resolution.Recommends: Kiva.org - Loans that change lives.
Recording an Xbox 360 using VGA without inducing lag
By DaOneEnOnly in forum Capturing and VCRReplies: 24Last Post: 4th Oct 2010, 07:21 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
XBOX 360 Capture with VGA connection
By bigboss50 in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2009, 23:21 -
Record XBOX 360 to Laptop using a VGA cord
By Renzeko in forum Capturing and VCRReplies: 1Last Post: 18th Jul 2007, 21:35
