Dear Friends,
i am watermarked a video according to this topic (with the help of this topic.)
https://forum.videohelp.com/threads/191496-Put-a-custom-watermark-on-your-video
After all the procedure can u please tell me "How to save the Video to same .avi format and Without exceeding the Size.That is;The Source Video is a 700MB DVD RiP.But after Clicking "file->Save as AVI" it is making a large avi file on my HDD (Greater than 6GB..!).How to make a perfect out put friends...?.I am using VirtualDUB 1.9.8.Please Replay urgently.....
Jithesh
You can Mail Me tooooojithuelad@gmail.com
Getting More Complicated.....Is there Any Simple Way than this....?.....
As soon as you add to....or change a video.....it needs re-encoded. No way around it.
And you don't need ALL of that guide.....just the output section. -
Video > Full processing mode > Video > Compression > XviD or DivX (quantizer 3).
If you want the watermark to show through the whole movie then you'll have to recode the whole movie. If you want it to show at different places in the movie then you can use the Logo filter in blend mode with the curve editor and use Smart render to only recode where the watermark is.
Saving in VirtualDub
By aaxpers in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2012, 12:02 -
Error when saving from VirtualDub as AVI with compression
By Thread7 in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2010, 21:41 -
VirtualDub: Saving Segmented Avi
By Ruro Jiruries in forum EditingReplies: 0Last Post: 18th Jun 2009, 07:13 -
By Qrees in forum EditingReplies: 6Last Post: 5th Jul 2008, 10:06 -
VirtualDub error while saving with subtitle on
By ajumma in forum SubtitleReplies: 0Last Post: 3rd Jun 2007, 01:35
