OK, I am trying to take audio from a DVD I recorded with my camcorder (saved as a movie clip) and combine with pictures to make a slide show with me talking. I have Neuro smart start essentials and Windows movie maker. If you could point me in the right direction, that would be great! thanks so much!!!
Extract the audio from the dvd and convert it to wav. See https://forum.videohelp.com/topic369269.html#1977241
thanks, I'll have to try, that, I have been learning so much on here. thanks for you help.
OK, I have tried and here is what happened....
I downloaded DVD Fab but I didn't know what to save it as...wav was not an option so I saved it as an MPEG4, then I went to my AVS audio editor changed it to wav file and now I am good except for 1 problem. When I recorded my audio via DVD camcorder and went to copy to my computer, it has my 6 minute continuous video into 14 different movie clips. Now when I converted all the different files and attempt to put them all together, there are breaks inbetween. How do I keep this from happening?
Thanks again
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 18:28 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 03:06
