Hi all:
I have some video files that I would like to keep and record to a DVD, but those files (I have 10 episodes) are causing some troubles.When I am browsing trough its folder my Explorer crashes, when I try to open them with some programs , like Gspot,
medialinfo etc... those programs crash too.But this is not happening evrytime.Sometimes I manage to open them or even make a copy using avidemux.One thing is for sure sooner or later I will have a crash on my explorer when browsing those files(I dont even need to play them)!!!.Any idea of what is wrong with those files.
Can i do something so recover them ??
tks in advance
some specs of these files : DIVX STYLE "PACKED BITSTREAM" AVI
CODE DX50 DIVX 5.1.1 - PICS. 25000
AUDIO 0X2000 (DOLBY AC3) 48.000 HZ 192 KB/TEREO 2/0
It sounds like the explorer preview crashes, try disable the preview. See https://forum.videohelp.com/topic304930.html#1547155
And have you installed any codec packs or other video tools lately? then try uninstall it. -
Hi Baldrick:
The first thing that came to my mind was really to check if I had installed any codecs lately.Nut no, I had not.
Besides that I uninstalled divx and Xvid to see if that was the problem (I use Kmplayer so I dont need any codec packs)
I will check preview disabled.
One thing I can add Is that I managed to burn 5 of those video files into a DVD.
Tried to play them and 4 played fine 1 freezed Kmplayer !!! I think that among the 10 files some have problems and some dont.
will keep trying.I wonder if I manage to convert to another format what will be the result !!!what format do you advice ??DVD ??? -
Ok so I did the following:
First removed image preview with the command regsvr/32 /u shimgvw.dll nothing happened still crashing
Then removed media preview and it stopped crashing.
In sum : that doesnt means the files are good.Right ?? there must be something wrong with those files.
The functions I disabled (image and media preview) are they important or not ?? shall I keep changes ?? -
hilario,
For playback, you're correct, kmplayer has its built-in codecs so you should be fine. I've used VLC and MPCHC but have stayed with MPCHC. Same idea, self contained.
However, that's not the case with media preview/thumbnails views. These require the correct and current codecs installed in order to display them. Your excellent decision to avoid a 'codec pack' was a good one. Though I don't use it, I've seen other members in good standing here recommend using ffdshow. If you want to keep the preview this may help take care of the problem.
I had the same problem (crash on preview) a while back and narrowed it down to an older version of xvid. Going to the author's site and downloading the most current version (I needed the latest for Vista compatibility) fixed the problem. Now that I think about it, the xvid problem was the second time it happened to me. The first time the preview/thumbnail thing happened was an issue with Nero. I didnt' used it much so got simply got rid of it. Had to reassociate some file extensions but all was well.
Anyway, there shouldn't be any problem with media preview if all the files your dealing with show the same settings you list. If there are, there's probably something wrong with the files themselves.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 02:25 -
Sporadic problems rendering HD video files...need a set of do's and don'ts
By acfalk in forum Authoring (Blu-ray)Replies: 0Last Post: 7th Mar 2011, 15:15 -
Problems converting video files .MOD to anything
By daka in forum LinuxReplies: 0Last Post: 24th Dec 2010, 13:16 -
(MKV) Audio/Video synching problems after remuxing the same files I demuxed
By Sigma X Virus in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2009, 16:27 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
