Results 1 to 30 of 44
    Jan 2009
    What's the best way to do this?
    You can
    Convert to uncompressed video or dv-avi or avi lagarith using virtualdub with the wmv plugin.
    Or convert to dv-avi using Windows Movie Maker.
    Or convert to avi huffyuv or dv-avi using avidemux.
    Uncompressed video is HUGE(file size) while lagarith, huffyuv is a bit smaller and dv-avi smallest but limited to 720x480x29.97fps/720x576x25fps.
  3. Member fitch.j's Avatar
    May 2009
    Depending on the source file, dv-avi may not give you lossless results due to its limitations.
    Do you have information on the .WMV you are trying to convert?
  4. Banned
    Freedonia
    DaneClark - When you say "AVI" do you really mean Xvid or Divx? The reason I am asking is that Baldrick's answer won't be very helpful for you if you really mean Xvid or Divx. AVI containers don't have to contain Xvid/Divx and he answered your question with some options that don't involve Xvid/Divx.
  5. It's possible to remux WMV into AVI with no change in quality if the video has a constant frame rate. This probably isn't really what you want to do though.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    I assume you want to edit with something doesn't support wmv.
    Jan 2009
    I mean DIVX.
    The DVD player hooked up to my TV can play .AVI's that have been burned onto a cd-r, but it can't play .WMVs. I want to edit videos with Windows Movie Maker and play them on my TV, but Windows Movie Maker only saves movies as .WMV (or DV-AVI'S which are way too huge too fit on any disc) I want to turn the .WMVs that I make into .AVIs that have the same quality as the original .WMV it was converted from.
  8. You can't without losing quality. For it to work on your DVD player you would have to re-encode to xvid / divx (or mpeg2), which is lossy.
  9. Get VirtualDub and the WMV source plugin. Encode with Xvid or Divx in single pass, target quantizer mode (Divx calls it 1-pass quality based), with a quantizer of 2 or 3. 2 is visibly nearly identical to the source, 3 has a little macroblocking but you won't notice at normal playback speeds.
    Jan 2009
    Jagobo, will that leave it with a reasonable file size?
  11. At q=2 the file will probably be bigger than the WMV source. At 3 a little bigger. But a lot depends on the source.
    Jan 2009
    when I opened the .WMV with virtual dub, all I got was a blank screen saying "missing codec."
  13. Originally Posted by DaneClark
    how do I get into those settings on virtual dub?
    In VirtualDub select Video -> Compression. Scroll down to Xvid (install Xvid if you haven't already). Highlight Xvid MPEG-4 Codec then click on the Configure button. That will bring up the Xvid config dialog where you can set Encoding Type to Single Pass. If the button below the lable Encoding Type says Target Bitrate click on it and it will change to Target Quantizer. Set the Quantizer value to the right.
    Also, when I opened the .WMV with virtual dub, all I got was a blank screen saying "missing codec."
    You need a VFW WMV1 or WMV3 decoder. You can get this from Microsoft:
    http://download.microsoft.com/download/9/8/a/98a6cb2d-6659-485e-b1f9-2c0d9bf6c328/wmv9VCMsetup.exe
    Or you can try using the DirectShow source plugin for VirtualDub instead of the WVM plugin. If your system as WMP installed DirectShow WMV1 and WMV3 decoders should already be installed.
    Jan 2009
    Okay, now I can get the video to play, but I get a message saying "no audio decompressor could be found to decompress the source audio format." and there's no sound.
  15. What kind of wmv audio ? If its wma pro, you can't use vdub without an avs script. If you don't know what kind, use mediainfo or gspot to identify. If it's wma2, you need a decoder called
    DivX ;) Audio
    Jan 2009
    How do i determine what kind of WMV audio my file has?
  17. Mediainfo or gspot
    Here's the link for audio decoder for 0x0161 (WMA v2)
    https://www.videohelp.com/tools/DivX_WMA_Audio
  18. Member
    Jan 2009
    My computer doesn't know how to open the .acm extension
  19. To install ACM type codecs, you right click the .inf file and select "install". I think that one comes with an installer "register.exe"
    Did you confirm it was WMAv2 ?
    Jan 2009
    I checked mediainfo and it said my file had a wma2 codec. I installed the Divx WMA Audio codec, but I stil can't hear anything when I play the file in Virtualdub, altough it doesn't give me the "no audio decompressor could be found" error anymorel.
    Edit -
    No wait, I'm still getting the message
  21. does the codec id 0x0161 match ? did you exit & restart vdub (you might have to reboot as well, but I doubt it)
    If you can't get it to work you can try avisynth or the directshow plugin
  22. Member
    Jan 2009
    Okay, I tried installing it using register.exe and got this little gem:
    "an error occured while copying file DivxAudioCompressor4.02.inf
    cannot copy file to destination directory"
  23. Vista? What OS? x64 ?
  24. Member
    Jan 2009
    vista
  25. Are you running as administrator?
    There are some hacks to install 32-bit .inf you can try
    https://forum.videohelp.com/topic364494.html
    Instead, it might be easier to use avisynth + directshowsource(), or vdub directshow import plugin
  26. Member
    Jan 2009
    I'll try the vdub directshow method. How do I do that?
  27. download the plugin (newest is 0.5 on page3, scroll down for 64bit version if that's what you need) and put in your vdub plugins (or plugins32 folder)
    http://forums.virtualdub.org/index.php?act=ST&f=7&t=15093&st=0
    You should be able to open the wmv directly in vdub then (you might need wmp11 installed); if not, the avisynth method should work
    Another option is to use avidemux which supports many types of wmv natively
  28. Member
    Jan 2009
    I already tried that and it didn't work.
    What about the avisynth method?
  29. Install WMP11, avisynth
    Open a text file in notepad in the same directory as the wmv file, write the following, and change the extension from .txt to .avs. Change the filename from "file.wmv" to match yours
    DirectShowSource("file.wmv")
    Open that .avs with virtualdub . If you are doing a straight encode without filtering , use video=> "fast recompress" mode
  30. Member
    Jan 2009
    Does it matter what I name the .avs?
