General topic for people using BD Rebuilder. List your cpu and load.
I'm using an Intel Pentium D 3.0 dual core with 4 gb of ram. Backing up to BD25 and cpu load is 100 percent. Takes anywhere from 24 to 48 hours to complete.![]()
Results 1 to 24 of 24
I used to take 40+ hrs w/ a AMD X2 6000+ reencoding to BD-9
I have upgraded to a Phenom II X4 940 OC'd to 3.8 Ghz w/ 8GB of ram and have got my times under 4hrs for BD-9
I just upgraded from a 6x LG BD/HD-DVD ROM to a 8x Pioneer BD-RW and am going to do my first reencode to BD-25, will report results
I believe the cpu load will always be 100% on any cpu (on the 2nd pass)
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
not yet bro', but shortlyOriginally Posted by mrswla
ocgw
2 x Quad Intel Xeon E5420's (8 cores total), all at 100% during encoding.
Average re-encode time from BD50 down to BD9 on Highest quality setting = 3 hours.
- Using DaemonTools with mounted ISO
- BD Rebuilder v0.20.09 (might be faster with latest 0.21.01, but I don't know) -
Ocgw,
What MB are you using? I think I'm going to get the Phenom II x4 955 cpu, but I've heard comments that some of the AM3 boards are not very good at OC'ing.
Thanks,
mrswla -
I have a 3.0Ghz Woldale ( 2 cores ) with 4GB ram, takes me 12-18 hours. I guess I need to upgrade. I usually run this program overnight.
That's not all that bad. Are you backing up to BD5, BD9 or BD25? Normally takes me about 24-36 hrs to back up to BD25 with my pentium D 3.0ghz (Presler) dual core.
Example, Paul Blart Mall Cop took me 27.5 hours to reencode to BD25 at High Quality in Movie Only mode. Not the best of movies but just an example. :P
I run my Phenom II 920 at 3.3Ghz on a Gigabyte GA-MA78GM-S2H MB. It has the same performance as my Intel PC with a Q9300 OC'd to 3.3Ghz, but at a lower cost. I don't use BDRB that much, but processing a BD to to DVD-9 takes about six hours total using RipBot for a MKV conversion. For AMD processors, I've had much better success with Gigabyte MBs. I'm using a Micro-ATX MB here as it's a HTPC and the case is small. The full ATX MBs have a lot more OC options.
I would hope your CPU is running close to 100% on all cores for that type of encode or you likely have a problem.
Yeah, I was a little quick to assume that quad cores would not be fully used.Originally Posted by redwudz
You can change the CPU settings if you needed to multitask, and reduce the CPU usage percent, but it would slow your encoding. Not all codecs can use all cores, but when they do, it usually speeds up the encode considerably. Divx does well using a quad core and so does H.264. I've had mixed results with Xvid, but probably my version or the settings. MPEG, not so good.
Those are just my observations, not necessarily fact.
I am using the GIGABYTE GA-MA790X-UD4P AM+ 790X ATX AMD MotherboardOriginally Posted by mrswla
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
It is 1 of those new "2 ounce" Gigabyte mobo's
"5 eggs" @ newegg
940's get 3.8Ghz on air on average, you should get around 4.0Ghz w/ a 955
ocgw
BD Rebuilder has a setting called "idle process" it will use all your cores 100% but you can still multi-task like it isn't even runningOriginally Posted by redwudz
for example: I was using BD Rebuilder to convert a BD movie file to BD-9 while @ the same time ripping a BD from the disc to HDD, then my mom showed up and asked me to copy a DVD for her, I started showing her a blu ray from the HDD, when the movie was done ripping I burned her a DVD in the corner of the screen w/ nero while we were watching the blu ray, and I had never stopped encoding
multi-tasking w/ heavy weight apps lol, not office fluff
ocgw
I'm usually backing up BD25. Sometimes I'll do a BD9, but I've never done a BD5. I will say this software is shockingly good at BD9. The average Joe probably wouldn't be able to tell the quality difference between a BD9 copy and a bought Blu Ray without close scrutiny.Originally Posted by mrswla
I have a q9650 3.0ghz during encoding it runs at 50-C IS THIS SAFE
Yes that is safe at 50c but perhaps you could reseat your cpu and heatsink fan to achieve cooler temps. Or buy a aftermarket heatsink fan if you're using the crappy Intel stock heatsink fan. According to the Intel specs. the temp you have is safe.Originally Posted by get Sum 76
http://processorfinder.intel.com/details.aspx?sSpec=SLB8W
I do encoding but with DVD REBUILDER PRO using my Q9550 that's overclocked to 3.60ghz but my temps don't go over 40c. But I use a aftermarket heatsink fan that uses a push/pull configuration. -
In total agreement w/ budz, but if you run this experiment you can drop your temps dramatically, sounds like you are not overclocking, so you may be feeding your cpu a lot more v that it needs to run stable, try this, drop your cpuv 1 notch @ a time, & test it out for a while for stabilty, if you drop your cpuv .2v I bet your temps will drop 5-7c, maybe even 10cOriginally Posted by budz
ocgw
Thanks budz I do still have the crappy intel fan and I kind figured I should just buy a aftermarket one.So on the link you sent me the cpu can be safe up to 71.4c correct.Thanks
also to lower the voltage on the cpu that has to be done in the bios or in a driver on the motherboard disk
Yes, in BIOS is correctOriginally Posted by get Sum 76
ocgw
Ok, finally updated my system. Thanks to OCGW and Redwudz mainly, but also to everyone else here on the boards.
System specs:
AMD Phenom II X4 955 3.2GHz
Gigabyte GA-MA790XT-UD4P
G.Skill 4GB DDR3 1333 (2x2GB)
ATI Radeon HD4650 1GB DDR2 (not a gamer so don't need anything special)
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V Power Supply
ANTEC Nine Hundred Case
Real world BD Rebuilder tests (all tests were run on Full Backup, "Quicker" Encode for Extras; Highest setting (very slow); Target size BD-25):
The Wrestler 30.44GB to 21.9 GB 10hrs. 6mins. 24secs.
[17:38:23] BD Rebuilder v0.22.02 (beta)
- Source: THE_WRESTLER
- Input BD size: 30.44 GB
- Approximate total content: [03:07:24.032]
- Target BD size: 22.46 GB
[17:38:23] PHASE ONE, Encoding
- [17:38:23] Extracting audio/subs [VID_00305]
- [17:38:30] Reencoding: VID_00305 (1 of 7)
- [17:39:59] Extracting audio/subs [VID_00302]
- [17:40:06] Reencoding: VID_00302 (2 of 7)
- [17:41:16] Extracting audio/subs [VID_00304]
- [17:41:26] Reencoding: VID_00304 (3 of 7)
- [17:43:50] Extracting audio/subs [VID_00303]
- [17:44:02] Reencoding: VID_00303 (4 of 7)
- [17:46:49] Extracting audio/subs [VID_00301]
- [17:47:34] Reencoding: VID_00301 (5 of 7)
- [17:54:57] Extracting audio/subs [VID_00300]
- [17:56:12] Reencoding: VID_00300 (6 of 7)
- [18:09:17] Extracting audio/subs [VID_00002]
- [18:25:58] Reencoding: VID_00002 (7 of 7)
[03:44:13]PHASE ONE complete
[03:44:13]PHASE TWO - Rebuild Started
- [03:44:13] Rebuilding BD file Structure
[03:44:47] - Encode and Rebuild complete
[03:44:47]JOB: THE_WRESTLER completed.
Underworld: Rise of the Lycans 41.31GB to 22.7GB 8hrs. 52mins. 43secs.
[08:40:43] BD Rebuilder v0.22.02 (beta)
- Source: UNDERWORLD_RISE_OF_THE_LYCANS
- Input BD size: 41.31 GB
- Approximate total content: [02:42:58.043]
[08:40:45] PHASE ONE, Encoding
- [08:40:45] Reencoding: VID_00275 (3 of 19)
- [08:42:19] Extracting audio/subs [VID_00285]
- [08:42:26] Reencoding: VID_00285 (4 of 19)
- [08:44:02] Extracting audio/subs [VID_00263]
- [08:44:09] Reencoding: VID_00263 (5 of 19)
- [08:45:45] Extracting audio/subs [VID_00277]
- [08:45:54] Reencoding: VID_00277 (6 of 19)
- [08:47:44] Extracting audio/subs [VID_00264]
- [08:47:55] Reencoding: VID_00264 (7 of 19)
- [08:50:49] Extracting audio/subs [VID_00276]
- [08:51:00] Reencoding: VID_00276 (8 of 19)
- [08:53:23] Extracting audio/subs [VID_00283]
- [08:53:34] Reencoding: VID_00283 (9 of 19)
- [08:56:39] Extracting audio/subs [VID_00284]
- [08:56:51] Reencoding: VID_00284 (10 of 19)
- [08:59:39] Extracting audio/subs [VID_00330]
- [08:59:51] Reencoding: VID_00330 (11 of 19)
- [09:03:01] Extracting audio/subs [VID_00280]
- [09:03:14] Reencoding: VID_00280 (12 of 19)
- [09:06:36] Extracting audio/subs [VID_00282]
- [09:06:50] Reencoding: VID_00282 (13 of 19)
- [09:10:01] Extracting audio/subs [VID_00278]
- [09:10:15] Reencoding: VID_00278 (14 of 19)
- [09:13:32] Extracting audio/subs [VID_00286]
- [09:14:02] Reencoding: VID_00286 (15 of 19)
- [09:20:40] Extracting audio/subs [VID_00287]
- [09:21:52] Reencoding: VID_00287 (16 of 19)
- [09:42:25] Extracting audio/subs [VID_00289]
- [09:44:05] Reencoding: VID_00289 (17 of 19)
- [10:11:06] Extracting audio/subs [VID_00288]
- [10:13:40] Reencoding: VID_00288 (18 of 19)
- [10:58:02] Extracting audio/subs [VID_00262]
- [11:15:21] Reencoding: VID_00262 (19 of 19)
[17:31:38]PHASE ONE complete
[17:31:38]PHASE TWO - Rebuild Started
- [17:31:38] Rebuilding BD file Structure
[17:33:26] - Encode and Rebuild complete
[17:33:26]JOB: UNDERWORLD_RISE_OF_THE_LYCANS completed.
The Curious Case of Benjamin Button 45.17GB to 22.1GB 11hrs. 21mins. 55secs.
[09:27:47] BD Rebuilder v0.22.02 (beta)
- Source: BENJAMIN_BUTTON_DISC1
- Input BD size: 45.17 GB
- Approximate total content: [02:48:48.159]
[09:27:47] PHASE ONE, Encoding
- [09:27:47] Extracting audio/subs [VID_00255]
- [09:28:15] Reencoding: VID_00255 (1 of 2)
- [09:32:55] Extracting audio/subs [VID_00237]
- [10:01:15] Reencoding: VID_00237 (2 of 2)
[20:49:24]PHASE ONE complete
[20:49:24]PHASE TWO - Rebuild Started
- [20:49:24] Rebuilding BD file Structure
[20:49:42] - Encode and Rebuild complete
[20:49:42]JOB: BENJAMIN_BUTTON_DISC1 completed.
Donnie Darko 42.55GB to 22.4GB 14hrs. 37mins. 19secs.
[08:32:19] BD Rebuilder v0.22.02 (beta)
- Source: DONNIE_DARKO
- Input BD size: 42.55 GB
- Approximate total content: [04:11:10.180]
[08:32:21] PHASE ONE, Encoding
- [08:32:21] Extracting audio/subs [VID_00101]
- [08:32:31] Reencoding: VID_00101 (1 of 4)
- [08:35:12] Extracting audio/subs [VID_00100]
- [08:35:24] Reencoding: VID_00100 (2 of 4)
- [08:38:27] Extracting audio/subs [VID_00097]
- [08:50:02] Reencoding: VID_00097 (3 of 4)
- [15:29:33] Extracting audio/subs [VID_00098]
- [15:44:14] Reencoding: VID_00098 (4 of 4)
[23:09:23]PHASE ONE complete
[23:09:23]PHASE TWO - Rebuild Started
- [23:09:23] Rebuilding BD file Structure
[23:09:38] - Encode and Rebuild complete
[23:09:38]JOB: DONNIE_DARKO completed.
Couldn't even imagine how long these would have taken on my old system, as I wasn't using Highest setting and it was taking a minium of 24 to 48hrs to encode main movie only.
Not bad, especially for a full backup and w/o overclockin'
ocgw
Encode for lowest CPU load while playing in Windows Media Player
By IriTrisha in forum Video ConversionReplies: 8Last Post: 15th Apr 2012, 10:23 -
x264_64.exe cpu load
By Ennio in forum Video ConversionReplies: 8Last Post: 8th Apr 2012, 10:21 -
BD Rebuilder
By santino_avi in forum Blu-ray RippingReplies: 4Last Post: 17th Jan 2010, 11:31 -
Why so much CPU load when looking at YT comments page
By brassplyer in forum Video Streaming DownloadingReplies: 7Last Post: 28th Dec 2008, 06:43 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
