    May 2008
    When I use AutoGK to compress movies I get this error message after it does the decoding and encoding, it says:
    A Field order transition was detected. You may need to use the fix DV tool to repair this stream. Refer to the DGIndex manual for details.
    Anyone know what this means and if it's a problem and what I can do to fix it?
    May 2008
    sorry, it's the D2V Tool, not DV tool, typo on my part
    Aug 2006
    See manono's post here:
    https://forum.videohelp.com/topic350517.html
    If you want more info, look here:
    http://forum.doom9.org/showthread.php?t=130378
