OK, I know lots of info here on this, believe me I've looked and am now more confused. I have made DVDs from camcorder DV footage and photos for years and at one time understood the proper encoding settings. but I had them as defaults in my software, then just bought a new Movie Edit pro 11 Plus that is sold in the UK and I am in the US so the defaults are not what I need. Alas, I need to have a refresher course.
So, DV and jpg edited then encoded to DVD compliant mpeg2. This is for DVD playback from standalone player to TV. I select MTSC 720 x 480. NOW I have 3 choices....1. Interlaced Bottom Field first; 2. Interlaced TOP field First, or 3. Progressive. I then set the bitrate, etc. which I know how to do.
So, which should I select? Does it matter what player it will be shown on (US only)? Also, I do show some of the videos via projector from my laptop, so would I encode the same way for that or better to use a different choice? I use Power DVD and a few other players.
If your encoding DV then use interlaced bottom field first.
Donadagohvi (Cherokee for "Until we meet again") -
Depends on the source, if your source is a DV device then as mentioned its bottom filed first. Here's old thread with more deatail:
https://forum.videohelp.com/topic257631.html -
Also depends on your encoder: if it allows for independent input/output field order settings (like CCE), then it is possible to make a TFF encoding from a BBF video like your DV (most commercial DVDs are encoded TFF). With CCE you anyway do these settings manually.
In other cases it is more safe to select the same output field order as that of your source (BFF for DV). If your encoder reads the field order of imported video automatically, it is useful to check whether it shows it correctly.
NTSC : progressive or interlaced
By mathmax in forum Authoring (DVD)Replies: 54Last Post: 2nd Feb 2012, 08:06 -
Question about x264's interlaced encoder vs. progressive
By Asterra in forum Video ConversionReplies: 4Last Post: 9th Jul 2011, 17:13 -
Top and Bottom subtitles on dvd
By loster in forum SubtitleReplies: 3Last Post: 1st Aug 2010, 00:34 -
Question - Black bands on top and bottom of the screen. (16:9 TV)
By Rainbow1962 in forum Newbie / General discussionsReplies: 31Last Post: 16th Jul 2009, 02:45 -
PAL to NTSC renders OK on top of picture, flickers on bottom half
By Exiled_Brit in forum Video ConversionReplies: 6Last Post: 21st Sep 2008, 15:31
