I am planing to switch from tmpgenc dvd author because my vesion is old but the new versions include junk such as divx authoring and encoding to mpeg. I plan to switch to dvd lab because it has more creative freedom at least in the creation of menus and more features. My questions are will there be a big jump in terms of complexity? Also is there a need for an internet connection to validate the liscence periodically (This is my main compliant with TDA).![]()
I switched from TDA to DVD Lab Pro and found the building of the DVD menu structure a bit more complex at first (TDA pretty much does this for you), but it became intuitive fairly quickly.
The main difference, apart from having a lot more control, was that it doesn't provide any templates for main menus and chapter menus. Sure, there's backgrounds and buttons, but you have to build the menus yourself.
I taught myself layers in Adobe Photoshop and how they can be imported into DVD Lab Pro so that each layer then becomes a selectable object which can then be used as links: Our Wedding, The Reception, Our Honeymoon, Play All etc.
So TDA is creative for you whereas DVD Lab Pro is a blank canvas for your own creativity.
If you do go to DVD Lab Pro (only) get the "Pro Extensions" - it makes life a lot easier for things like the setting of chapters and sorting out subtitles, especially in terms of timing for both as you can watch the video and audio together, frame accurate.
More on Pro Extensions:
https://forum.videohelp.com/topic333976.html#1733742
DVD Lab (Pro or otherwise) doesn't phone home.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I create all menus in Photoshop or Vegas, and use DLP for assembling and linking only. For that, it runs rings around most other tools for the freedom that it allows.
However you might also consider GUIForDVDAuthor as an alternativeRead my blog here.
@noemi7
that problem with rendering was fixed ages ago....you are a joke for bringing it up now.
No jaggies for AGES....
LOL!!!!!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
after reading through the docs I see that GUIForDVDAuthor will create the graphical buttons i want if tricks are used so I will probably just use that as its freeOriginally Posted by guns1inger
VLC looks washed out compared to WMP
By stringcheesy in forum Software PlayingReplies: 3Last Post: 11th Sep 2011, 23:27 -
DVD-rip compared to VHS
By Digiface in forum MediaReplies: 7Last Post: 4th Aug 2008, 12:34 -
ffmpeg avi to mpeg2 quality compared to other progs
By bagrol1 in forum Video ConversionReplies: 3Last Post: 19th Jul 2008, 08:09 -
flv server load compared to wmv
By Fking in forum Video Streaming DownloadingReplies: 1Last Post: 18th May 2008, 07:28 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04
