    May 2007
    I've got an avi (xvid encoded) vid and a separate sub file. I can't figure out how to have the subtitles automatically loaded with MPC. I have VMR9 renderless selected.
    Could someone help me?
  2. Do you have DirectVobSub installed?
    What file format is the sub?
    The sub file has to be the same name as the avi with both in the same folder
    (e.g. film1.avi, film1.srt)
    May 2007
    the extension name is .sub
    They are both the same name and in the same folder.
    I don't have directvobsub installed.
  4. Perhaps you should install it
    May 2007
    I installed the program and opened up the vid and still no subtitles.
    Any other ideas how I can get this to work?
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Google is your Friend
