as per this topic,
https://forum.videohelp.com/topic246952.html?highlight=remove%20constant%20noise
a constant noise source (buzzing) can be removed from an audio file.
I have the ulead video editing package.. I'd like to apply the technique to my wedding video (in a tower in Niagara Falls.. the "noise" of the Falls seems fairly constant.)
Can the ulead software do this or should I try another software (freeware perhaps.)
Thanks.
-Matt
I remember all these terms from my DSP class... Hanning and Blackman windows.. heh.
The first few voices are that of the minister: he's loud and it can be removed by selecting "just the Niagara Falls" background (just around that high frequency spike about 2/3 the way through).
However, our voices are heavily drowned out; our "signal to noise ratio" is way too low.
When I try the noise removal (I tried different noise removal dB levels), I don't get much signal left.
Right now I'm trying diff. noise removal levels and then trying to seperately select clipits of voice and amplifying them... it's working to some extent.
Any other suggestions?
-Matt -
https://forum.videohelp.com/topic337268.html
The water hissing is probably in the 4-7K range. I wouldn't use noise reduction, just cut the bands below 80hz and between 4000 and 7000hz
Background noise removal - Please help!
By maurof78 in forum AudioReplies: 2Last Post: 3rd Oct 2010, 09:24 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
removing background noise on a home made DVD?
By Rudyard in forum AudioReplies: 2Last Post: 22nd Jun 2007, 14:29 -
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 21:27
