I just installed the 2.5 Demo. The first time I loaded it, it loaded fine and I tried out some functions. When I tried to Preview the menu, it told me I didn't have a program assigned to Video_TS.inf files. I stopped SVCD2DVD and started Windows Media Player 10,and assigned it to play all of its media file types, including DVDs.
I then tried to restart SVCD2DVD, but it will not run. It gives an SVCD2DVD error box with an IO.Exception error. I have copied the error and it is as follows:
When I close the error box, SVCD2DVD completes the load, but if I try to do anything it throws an "Unhandled Exception" error.Version: SVCD2DVD 2.5 DEMO
Build: 2.5.3300.0
Type: System.IO.IOException
Source: mscorlib
Message: The process cannot access the file 'C:\Program Files\BadgerIT\SVCD2DVD v2.5 DEMO\%APPNAME%.EXE' because it is being used by another process.
InnerException:
StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at x3284ccece41ee22b.x3d0212ed6a5e5836.xe1d38190cee70 4ff()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
I have tried uninstalling and reinstalling SVCD2DVD (rebooting between). I have the latest MS .net frameworks 1.0, 1.1, 2.0, 3.0 installed. I even upgraded to Windows Media Player 11. But none of it helps.
Any ideas on why this is happening, and how to correct the problem?
Greg
Results 1 to 23 of 23
More info on this problem. I installed S2D on another PC I have, a Dell laptop with WindowsMediaCenterEdition. It started up OK. I added an assett. When I tried to Preview the menu, it gave me the same error, No DVD assigned by windows. After that, it will not load. It gives the same error as earlier post. It seems that there is some problem in processing the Menu Preview. Somehow it is not finding the DVD player and once it has that problem, it cannot recover, even if it is stopped and restarted. Or uninstalled and reinstalled. I don't know why it could not find the DVD player on my MediaCenterEdition. It came with the MS DVD player.
When I first tried the Preview, it said that there was no program associated with the VIDEO_TS.IFO file type. (This is from memory, as I cannot get back to that error message). -
Ok - i will look into this. If you reboot can you start the program (forgeting about the preview for now)?
No. Once I have tried the preview. it will no longer work. Even if I reboot, it still will not start. And if I uninstall it then reinstall it, it still will not start.
Can you try this build to see if it resolves the issue?
Thanks for the quick turnaround.
I tried it but it did not work correctly.
I installed the test version. It did started OK and I got to the main screen.
I added a large .ts file and started to process it.
It completed the conversion OK, but when it went to make the menu, it failed again. I was not able to get a copy of the error message. It was similar to the previous error on loading, something about mscorlib not being able to access the menu.exe (or something like that).
And now I can no longer load the program again. It is giving the same error as I reported above.
Greg -
Greg: I have made another build. It is at the same URL. Can you retry please?
ChrissyBoy,
Sorry, but that didn't fix it either. But I did manage to get the error report this time.
So I installed the latest version. It starts up OK. (I think it does this cause it gets a new ID when it installs?)
I created two movies, each with one MPEG asset.
I created a Menu with the two buttons, Plus Play All, and my photo.
I started the creation step.
It created the mpgs OK and created the menus OK as well.
It ran the "Encoding Menu" step.
The log reported "Encoding Menu ... Done"
And at that point it put up the SVCD2DVD Error screen. The data from that screen is as follows:
As you can see, it reported this error twice.Version: SVCD2DVD 2.5 DEMO
Build: 2.5.3301.0
Type: System.UnauthorizedAccessException
Source: mscorlib
Message: Access to the path 'C:\Documents and Settings\Greg\Local Settings\Application Data\Badger I.T\SVCD2DVD 2.5
DEMO\2.5.3301.0\menu\MenuMuxer.exe' is denied.
InnerException:
at System.IO.File.Delete(String path)
at x3284ccece41ee22b.xe679539bc4bbd8b5.xfeff58ae51b05 fd0(String xd168ac2ed64c4662)
at x3284ccece41ee22b.xe679539bc4bbd8b5.x865d1dce05e7a 87c(String xc7faa4629ea73ace, Boolean x1ebdb8fb1e9908a0)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Build: 2.5.3301.0
Source: mscorlib
InnerException:
After that, I cannot start the program. It reports the error at the top of this thread.
Greg -
Greg: I have made another build. It is at the same URL. Can you retry please? (This should nail it)
ChrissyBoy,
Thanks for the quick reply.
This build helped. It successfully completed building the DVD. Yeah!
However, after I completed the build, I tried to "Preview" the menu from S2D. As in my original report, it gave me the error that I did not have a DVD player assigned. And now, I cannot load S2D again. As before, it keeps giving the S2D error screen before completing the load, and will not successfully start.
Greg -
ChrissyBoy,
The production version of S2D seems to be working fine for me. I have not tried to use the Preview feature, since that is what caused all my problems and I want to make some DVDs. I have used it to create several DVDs today, and it is working well. Maybe when I get a little more time, I will try the Preview on my other PC.
Thanks for your efforts in trying to figure this out.
Greg -
Hello all,
I unfortunately also have this problem.
I have just loaded the trial version, adjusted some settings without even importing a file..and now get the message..I think after trying to preview...
Build: 2.5.3302.0
Source: mscorlib
InnerException:
I've tried several versions, reloads , reboots etc etc with no effect.
the applicaiton is locked as soon as I open it.
I am particularly interested in this application as I understand it does a good job of converting pal to ntsc.
I have pal mpeg2 home hd movies and require the format changing to ntsc mpeg2 hd for authoring and playing on a hde1.
I HAVE TRIED FOR MONTHS TO GET GOOD QUALITY, SMOOTH AND CRISP QUALITY OF CONVERSION WITHOUT SUCCESS.
It appears to me the basics in this software should do what other experts can do uniquely with avisynth etc.
Unfortunately I must be too stupid to figure this out and am looking desparately for assistance.
MANY MANY THANKS IN ADVANCE. -
Hi - i can't replicate the issue but here is a newer build for you to try:
http://software.badgerit.com/Releases/SVCD2DVDv2.5DEMOTEST.zipSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
hi and thanks so much...
IT NOW WORKS !
After spending a few months with variants of avisynth, and getting nowhere, I feel very helpless and nothing but admiration for your capablilities.
Having now got the application going,...
Have you any idea if/how I may be able to convert my pal mpeg2 files to ntsc mpeg2's?
(I obviously only have the source mpegs rather than an already authored dvd)
Thanks. -
hi i just got done installing this app which looks really cool but after it started up the first time it will no longer run at all.
i have also tried repairing, uninstalling , re-installing, rebooting and completely shutting the comp down and restarting
here is the log file
Build: 2.5.3303.0
Source: mscorlib
Message: The process cannot access the file 'F:\Program Files\BadgerIT\SVCD2DVD v2.5 DEMO\%APPNAME%.EXE' because it is being used by another process.
InnerException:
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc) -
I have tried installing the latest version and get this error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: Window class name is not valid.
at System.Windows.Forms.NativeWindow.WindowClass.Regi sterClass()
at System.Windows.Forms.NativeWindow.WindowClass.Crea te(String className, Int32 classStyle)
at System.Windows.Forms.NativeWindow.CreateHandle(Cre ateParams cp)
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.ListView.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.OnVisibleChanged(Even tArgs e)
at System.Windows.Forms.ScrollableControl.OnVisibleCh anged(EventArgs e)
at System.Windows.Forms.Control.OnParentVisibleChange d(EventArgs e)
at DevComponents.DotNetBar.PanelEx.OnVisibleChanged(E ventArgs e)
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at DevComponents.DotNetBar.PanelEx.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SVCD2DVD
Assembly Version: 2.5.3300.0
Win32 Version: 2.5.3300.0
CodeBase: file:///C:/BadgerIT/SVCD2DVD%20v2.5/SVCD2DVD.exe
DevComponents.DotNetBar2
Assembly Version: 6.9.0.0
Win32 Version: 6.9.0.0
CodeBase: file:///C:/BadgerIT/SVCD2DVD%20v2.5/DevComponents.DotNetBar2.DLL
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Deployment
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
Accessibility
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/BadgerIT/SVCD2DVD%20v2.5/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.CodeLock
CodeBase: file:///C:/BadgerIT/SVCD2DVD%20v2.5/Interop.CodeLock.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I have also tried running the 1.5 version and get a message saying invalid signature . I really miss this great proggy, I hope you can help. cheers, Rab -
When do you get this error? On start up or during processing?
Hi Chris, I get this when I try to run the proggy, ..cheers,Rab
Can you try the latest version please to see if this is resolved?
ive installed the latest version Chris and still get the box popping up with " windows class name invalid" , here are the details
mscorlib
SVCD2DVD
Assembly Version: 2.5.3500.0
Win32 Version: 2.5.3500.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/SVCD2DVD.exe
Assembly Version: 7.0.0.3
Win32 Version: 7.0.0.3
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/DevComponents.DotNetBar2.DLL
System
System.Drawing
System.Deployment
Accessibility
AxInterop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/AxInterop.CodeLock.DLL
System.Xml
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/Interop.CodeLock.DLL
enabled.
For example:
<configuration>
</configuration>
cheers,Rab -
Rab, is this on XP? If so can you try the following:
https://forum.videohelp.com/topic334156.html#1734407
and let us know the outcome?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I downloaded the MSVBVM60.DLL file, and reinstalled svcd2dvd and it seems to have done the trick, I haven't tried to convert anything yet but at least it loads up whereas before I always got the error code and no further. Many thanks Chris for taking the time and trouble to try and sort this out..cheers,Rab
unhandled exception - length cannot be less than zero
By warresg in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2010, 16:49 -
Getting error loading mpg that svcd2dvd created
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 1st Oct 2008, 12:14 -
An exception to the rule
By Jomapil in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2008, 08:30 -
svcd2dvd not loading aftere service pack 1 vista 64bit
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Apr 2008, 04:23 -
SVCD2DVD error on start up 'Application has generated an exception...'
By Turnstyle in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 16th May 2007, 03:53
