It's not perfect yet! I can't seem to get it to work without the 3 second pad. Maybe I'll have to resign and create that customized 3 second loading screen instead.
With regular H263, you can start it fine without any of these 3 seconds of pad. I'm guessing it is failing to encode because it's not finding at least 3 seconds of "stuff" to encode.
I'm tired from trying to get H264 to work without that header time.
Results 1,141 to 1,170 of 1969
look at it from a good perspective... now you have full and easy control of your thumbnail!
HQOriginally Posted by rajman
now its youtube's turn. we'll see how long this lasts hahaha
No, I meant it's all over:
YouTube re-encodes everything now (or reports an error). -
Heres my test video of using H264: http://www.youtube.com/watch?v=KBWMLmiNZDc
The total bitrate is <350kbps so no messing with the timestamp.
PS. Ignore the thumbnail at the start, it was for a previous test video that I just used on this XD -
Give it an hour and you'll be crying like a baby.Originally Posted by rajman
It will be re-encoded.
how long ago did that start happening?Originally Posted by FreeOurTube
So its all blocked yeh? H264 and VP6?
Not long ago.Originally Posted by frifox
Yes, and H.263. I made a test with one video after the first reports.Originally Posted by rajman
And I don't believe in coincidences. -
This was meant to be by the higher powers... of YouTube. Just listen to your last HQ video ever on YouTube:
http://www.youtube.com/watch?v=IIDLGi60r08
It's time for mourning.
if thats true, then the soundtrack of that video is RIGHT SPOT ON...
I suppose YouTube gave us something extra along with the 'My Account' format upgrade.
Yehh they now made 'my_videos2' as default now under 'My Account'....which I dont likeOriginally Posted by virtualgamesco
My bad, but Rajman and zappa have uploaded a few HQ just recently, lets see if they hold. Hoping they do.
I'll say there are some issues with the flv tool I released, and I'm using different methods at the moment.
If you're basing anything off the results of that tool, it is very picky with codecs, and audio formats.
With that said, FreeOurTube has done some amazing work and if he says video's are getting re-encoded I wouldn't doubt it. My last video upload was before that report so I'll try to test again with another upload. -
I work with FLV tags, and not by hex, nor by any other tool besides maybe ffmpeg. Here's an explanation of my current method by code. I think the code is easy to read but if you have questions about how that method works, just let me know.
Nevermind, my faultCode:static void youtube_patch() { int time_stamp_interval = 1; // 52 for H264 int pad_multiplier = 1; // 20 for H264 Console.WriteLine("\n\n\n[RUNNING YOUTUBE PATCH SCRIPT]\n"); create_flv_stub(output_flv_file, 5); generate_custom_video_flv_tag_with_ffmpeg(0, 640, 272); append_flv_tag("custom.ffmpeg.flv.tag", output_flv_file); generate_custom_audio_flv_tag("audio.flv.tag", 0, 128); append_flv_tag("audio.flv.tag", output_flv_file); generate_custom_video_flv_tag("rejector.flv.tag", pad_multiplier * time_stamp_interval, 0, 4, 3); append_flv_tag("rejector.flv.tag", output_flv_file); for (int i=(pad_multiplier*1); i<(pad_multiplier*2); i++) { generate_custom_audio_flv_tag("audio.flv.tag", i * time_stamp_interval, 128); append_flv_tag("audio.flv.tag", output_flv_file); } generate_custom_video_flv_tag_with_ffmpeg((pad_multiplier*2) * time_stamp_interval, 640, 272); append_flv_tag("custom.ffmpeg.flv.tag", output_flv_file); for (int i = (pad_multiplier*2); i < (pad_multiplier * 3); i++) { generate_custom_audio_flv_tag("audio.flv.tag", i * time_stamp_interval, 128); append_flv_tag("audio.flv.tag", output_flv_file); } if (padding_needed) { Console.WriteLine("Padding needed"); generate_custom_audio_flv_tag("audio.flv.tag", (long)Math.Ceiling(expected_duration / 1000) * 1000, 128); append_flv_tag("audio.flv.tag", output_flv_file); } else { Console.WriteLine("Final padding is not needed"); } append_flv_file(input_flv_file, output_flv_file, (pad_multiplier * 3) * time_stamp_interval); File.Delete("audio.flv.tag"); File.Delete("thumbnail.flv.tag"); File.Delete("rejector.flv.tag"); File.Delete("aspect.flv.tag"); File.Delete("custom.ffmpeg.flv.tag"); }
Previous code had bad reject frame! That's what I get for not testing
Blah. -
Thank you for your kind words; I wouldn't trust me too much, though.Originally Posted by zappa_engine
I tested with only one video.
The H264 video I uploaded didnt get reconverted and its stayed HQ overnight (12 hours): http://www.youtube.com/watch?v=KBWMLmiNZDcOriginally Posted by FreeOurTube
And the C243 also still works as my latest video has remained HQ after 7 hours -
It does work.Originally Posted by Spritemoney
http://youtube.com/watch?v=BR7OVsQsZwY -
Speaking as a musician with 1000 subscribers and over 150 videos on youtube...I'm about to pack it in with youtube and go to www.vimeo.com. I can upload my music in stereo and HD ..without any hassles .As a musician u reach a point where youtube...sound is crap and better options lie elsewhere.I may not get as many viewers at vimeo but I'll spend more time on the piano and less time trying to get stereo.. As a musician I dont want to spend hours searching the Internet trying to find a way to upload better audio to Youtube..Vimeo gives me the stereo audio without the hassles... ...Hello vimeo...goodbye Youtube. RIP
ok the strangest thing happened to me, with "certain" videos zappa's program work's for me, which is weird, like i was doing some tests, and "certain" videos work.Originally Posted by FoxLocked
I'm currently doing some tests, with FLV reader, and some other stuff, i'll say if they get reencoded or not
i'll say in one hr, cuz i g2g.
update: 1:22 Eastern USA time
FLV reader doesn't work but "FIG" does!!! -
"FIG" what the heck is that?
(in russian FIG = "the middle finger", hahaha) -
Hey Frifox and members of VideoHelp Forums.
I rendered the video in Sony Vegas using
480x360 Resolution
20 Frame Rate
1.0 Square
None Field Order
Then I rendered in my special encoder O_o (I made a special script based off your VMuTube scripts.
128 bitrate
20 frame rate
If you want to try the method, you should make the entire video stretch to 10:57 and have the ThumbNail picture in 5:27
Please Reply after you Watch
Trailer Video = 007 James Bond Quantum of Solace
Link = http://youtube.com/watch?v=43h2JbQHeCQ
Please reply to this and check out the video to see if it is HD or Not.
Lets hope that the HD in the video lasts...
View the Trailer in FULLSCREEN if you can't tell... (You Should be Able To)
-CJWEntertainment -
post some more tech details about this method of yours, and then we'll tell you if this method has been or hasnt been covered....
that article is from last year....Originally Posted by FreeOurTube
8)Adobe® Flash® technologies support the next-generation AAC audio codecs defined by the ISO/IEC 14496-3 (MPEG-4 part 3) standard, including Advanced Audio Coding (AAC) Main, AAC Low Complexity (LC), and High Efficiency AAC v2 Profile (HE-AAC v2, also known as HE-AAC+, eAAC, and aacPlus v2).
AAC Main adds perceptual noise shaping to the MPEG-2 version of AAC, improving quality at lower bitrates. AAC Main can handle up to five channels plus one subwoofer channel (5.1) in a single audio object. AAC LC is slightly less efficient than AAC Main and requires less CPU power to encode and decode. AAC LC is optimized for low-bitrate applications such as streaming. HE-AAC v2 is a superset of the AAC core codec that couples spectral band replication (SBR) and parametric stereo (PS) techniques to enhance frequency domain coding efficiency and improve the efficiency of low-bitrate stereo signals. HE-AAC v2 supports up to 48 audio channels and enables 5.1 and 7.1 surround sound experiences.
Source: Adobe -
I saved a video as 480x360 Resolution. Frame Rate = 20. Set field order to "None (progressive scan)" and set the pixel aspect ratio to "1"Frifox Wrote:
I rendered it as AVI and ran the script. (VmuTube V2)
VmuTube Settings: 128 Bitrate/ 100 KeyFrameRate
After I got the output file, I got the "default.flv" file from the C243 method.
I used the FLVBind command: FLVBind youtube-complete.flv default.flv utubevideo.flv
Finally, I uploaded my youtube-complete.flv file onto YouTube and VOILA! HD IT IS!
-CJWEntertainment
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09 -
Youtube - bad upload quality
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49 -
Poor quality following upload to YouTube-can anyone assist?
By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16 -
Poor Youtube Quality Upon Upload
By JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54 -
Youtube HQ upload slow on normal quality
By seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
