I want to take .mpg files to dvd with little or no increase in file size. I did it with tmpgenc3 but it took an hour and fourteen min to encode + burn time for a 30 min episode. I want something to do a 30 min vid in less than 30 min. Also, is there a program that will let you import disk image instead of file format to make a dvd menu?
Closed Thread
epox MOBO amdxp 2900+ @2.0 ghz
gforce fx 5200 256mb ddr dual mon 8x agp
2X512 mb ddr 3 300 gig hdd's
visionplus starbox
xp home reg.
First off... you should stick to one thread instead of double posting 8)
Second... well..... look at your original thread....
https://forum.videohelp.com/topic336307.html
Please do not post the same topic in more than one thread. Continue in: https://forum.videohelp.com/topic336307.html#1748323
Moderator redwudz
convertx todvd won't load
By xbill in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2010, 16:22 -
mini dv dvd todvd
By xbill in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2010, 11:48 -
Questions About DVDFab HD Decrypter; Ripping MPG
By neumannu47 in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2009, 19:55 -
How to adjust the audio to be all the same in every video file added todvd?
By f-zer0 in forum AudioReplies: 5Last Post: 27th Feb 2008, 19:01 -
starting out questions avi to mpg with the fixins
By xfaqtar in forum Newbie / General discussionsReplies: 4Last Post: 12th Oct 2007, 13:52
