Closed Thread
    Aug 2007
    OK I have a joycoder pv-330 portable dvr it records from tv and anything else with a video output. What i am wanting to do is strore my video files on this thing, my problem is everything that is recorded on the device is in avi format 320X240 with a 256kbps bit rate, with video compression XVID Now i can move the files back and forth from the the dvr to computer and i can take from from device and do anything i want to with the files, same as with all my other video files of which i own. Now when i right click and check properties then check summary it gives me my image info (width=320/height=240 and audio duration/bitrate=256kbps/sample size=16bit/format PCM) but under video it only shows video compression XVID......Now when i convert my other videos to the same specs and send them to the same folder where i pull the files the recorder saves they wont play????? Now on the new files when i check properties and click summary i get the same info as above mentioned but under video it also gives me (frame rate= 25 frames/second and data rate=78kbps, and video sample size =12bit) evreything looks to be the same the only difference is in my converted files i have more info.....does this have something to do with how the dvr records can anyone explain what i'm missing here???? thank you. i have MovAvi video converter 5.5, which pretty much allows u to do anything converting wise with your files you can think of, if you know what your doing???.which is where my problem is..lol.. i can convert videos for my PSP, my pocket PC, my ipod, even my girlfreinds cell phone. i can not for the life of me convert any of my files to play on this device....... i dont pretend to know what im doing im just figureing it out as i go, but this one has me stummped. thank you
    Dec 2004
    Triptonia
    if you want information on your files use gspot or mediainfo.
    then you can better compare
    gl
    USA
    icucmerc, please do not double post. Continue in: https://forum.videohelp.com/topic334463.html#1736218
    And in the future, please use a more desciriptive title, as in our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Moderator redwudz
