Hello,
I have converted a movie to DVD format (VOB files) but the stereo is in 2.1 channel sound, how can I convert it to 5.1 and then reauthor the DVD so that it has 5.1 sound instead?
What programs or tools do I need?
Thanks,
Ian
You can, but it's really a lot of work for not much gain. Most set top players do a decent job with 2 channel stereo converted to 'pseudo surround' sound. Here's a few threads that may give you some ideas:
https://forum.videohelp.com/topic326127.html
https://forum.videohelp.com/topic330921.html
https://forum.videohelp.com/topic326496.html
And welcome to our forums.
I'll modify the script to make it work with AC3 2 channel source files. Lemme know.
Steps you'll need to take:
1) Demux the audio and video from the VOB files - DGindex would prolly work well
2) Determine if there is delay that needs to be addressed on the 2 channel AC3
3) Run 2-5.1 upmix script
4) Remux the 5.1 soundtrack with the .m2v video file that was created by DGindex
Yeah, a fair amount of work. The script I put together was designed to create a 5.1 audio track for folks who wanted to create DVDs out of their AVI files. -
I've converted the VOB files and am using them in Videostudio 11 Plus, I have ticked the Surround Sound option and it is re-rendering it all as we speak.
The only problem is that it is now over the standard DVD size limit, can I use software to shrink the resultant video file to fit a single DVD?
I'll let you know what happens when the rendering is complete.
Many thanks.
Ian -
There is a piece of software called, funnily enough, DVD Shrink, which does exactly what it's name suggests.can I use software to shrink the resultant video file to fit a single DVD?Read my blog here.
How to add subtitles permanently to existing mp4 h.264 file???
By Patrick_H in forum SubtitleReplies: 20Last Post: 7th Aug 2014, 08:35 -
add tones to existing mp3 file
By lordhutt in forum ComputerReplies: 0Last Post: 28th Dec 2010, 14:25 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 19:57 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to add AC3 file to already existing menu
By chrishallowell in forum Authoring (DVD)Replies: 11Last Post: 14th Sep 2007, 13:32
