I have been editing and rendering 720 x 576 16:9 videos in Ulead VS9 to MPEG2 format. I have used the default PAL DVD profile for 16:9 and have also played around with the quality settings, the variable/constant bit rate settings of around the 8000kbps mark, upper lower field first and 2 pass encode, however I keep getting the same results on the output file. All of the output files image appears blurry/slightly smudged in comparison to the sharp quality of the original file which was a DVD Rip to MPEG format. I am wondering if there is anything I can try to resolve this or whether it is just a flaw of the Ulead MPEG Encoder or all video editing software. I know there is some loss during compression but I wouldn't have thought it would be this noticable.
Can you post a short segment of your original (non mpeg re-encoded) file for a look-see? 10-20 seconds should do it.
You don't have to recompress, look up "do not convert compliant files" in the manual. No quality loss and will save you the time required for reencoding.
This is relative to the source, selecting the wrong field order will result in a ghosting affect during fast action and panning.Originally Posted by kevluigi
More general Info here: https://forum.videohelp.com/topic257631.html -
I have put a couple of short clips on the net. The first is the source file before it was put through Ulead and the 2nd is the resultant output.Originally Posted by Soopafresh
http://www.hawthornbasketball.com.au/ulead/
thecoalman, If I have compiled a few clips together (who's source are MPEG2), when rendering it, don't I have to select an compressor? I can do an uncompressed AVI, but even this comes out a bit blurry when rendering with Ulead.
Thanks -
Here's the deal, assuming they are DVD compliant if you drop one clip on the timeline, set VS up properly you can create a disc without recompressing. If you have two clips with exact same specifications, bitrate, resolution etc. Again you can drop them on the timeline and no need to recompress, you can even add trasitions, titles and other things and it will only recompress what it has too.Originally Posted by kevluigi
What you can't do is add clips with multiple properties and export as the same file, that's true of any editor.
As I said look it up in the manual or try the Ulead forum, they will be able to provide you with better information.
You can try this thread here: https://forum.videohelp.com/topic325840.html
Check the post by GeorgeW -
Action packed sports. Very difficult to re-encode, especially the interlaced sources. Good advice here. Try to process as little as possible.
Or become a fan of cricket...
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 09:27 -
ULEAD VideoStudio trim
By dcmoser1952 in forum EditingReplies: 3Last Post: 24th Feb 2009, 15:43 -
Ulead videostudio clipping guide
By Bjs in forum User guidesReplies: 4Last Post: 26th Nov 2008, 15:23 -
Newbie wanting help? Import DVD/MPEG in Ulead VideoStudio
By Mark75 in forum EditingReplies: 4Last Post: 30th Oct 2008, 17:52 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 18:21
