Anyway on how to disable 1 of the audio and not the other as well?
If it's not possible, any converter to convert it to some other format so that VLC Player can plays it and select 1 of the audio?
Results 1 to 9 of 9
I tried merging but an error occurs, and shut down the entire programe. -
I only see one audio stream. This makes sense since I don't think the rm container is designed for multiple audio streams. You are supposed to use scripting for multiple streams.
rm container can have multiple video and audio streams as it is a streaming format. If it is true rmvb, it will have one video and one audio stream
GUImux.exe is for muxing video stream from one file with audio from another. It will show all streams in a multistream file but will not work with it.
GUImergeSS.exe is for extracting one video and/or audio stream and muxing into rm/rmvb format from a multiple stream file.
In your case the file contains exactly one video and one audio stream. It does not have two audio streams. Maybe the audio stream is stereo with one channel in one language and the other in a second language. -
if its just 2 audios merged into one audio stream and one video stream.. how to extract the 2 audios out of the one audio stream separately?
thanks
Help me automating demux-remux dual audio files...
By CactusMan in forum Newbie / General discussionsReplies: 8Last Post: 6th Jan 2012, 21:59 -
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 11:07 -
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 05:31 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42 -
dual audio mp4 to RMVB
By vipertongn in forum Video ConversionReplies: 9Last Post: 10th Jun 2008, 06:37
