Greetings all!
Do any of you know how to remove a logo from a dvd? Thanks!![]()
Results 1 to 14 of 14
How about a little more detail ?
If this a logo at the start of a film, or a water mark running throughout ?
Different problems require different solutions. Some are simple, some require that you pull apart the whole disc, process the video and re-encode it. Can't say which you need until you explain your problem more clearly.
Would you ring your mechanic and say "my car is making a noise, how do I stop it ?" with out telling him what sort of noise, and from where ?Read my blog here.
Ok. You're right.Originally Posted by guns1inger
I got some movies with logo in top-right side of the movie. The logo wiil stay always, is not watermark type, making the movie so boring.
More effort than it is worth, IMNSHO. You will have to demux the video from the disc, use a delogo filter (delogo, MSU logo removal) in virtualdubmpeg2, then re-encode the video and put it back into the DVD. Most delogo filters works best with watermark (that is, semi-transparent) logos, and are much less successful with solid colour logos. Finally, you will most likely end up replacing the current logo with either a blurry mark, or a shimmering blur.
Read my blog here.
Yep guns1inger got the basics covered there.
One more note - if it is a moving logo as in the picture spins or something you will have a really bad spot left over. The movement makes it impossible to recover anything.
You can fool around with the delogo process. It does work but the results aren't perfect and you probably won't like the results after all the work you have to do.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I have a similar problem. My DVD has an annoying flickering white line at the bottom of the screen.
I loaded the offending VOB into VirtualDubMod and used the built in filter to put a little black patch over the line. This seems to work fine. I'm now outputting to an uncompressed AVI.
Is there any way to avoid a re-encode? I'm just worried that the first VOB will look different to the parts because it's been through a re-encode process.
Thanks in advance. -
There is no way to change the video image without re-encoding. You may also have issues just doing one VOB in the titleset, but see how you go.
Depending on what encoder you are using, you may not have to render to uncompressed avi as an interim. Use the frameserver function to pass the processed video to your encoder instead. Much less disk space required.Read my blog here.
Hai Friends Good Morning to All...
I am newbie to this site. I have one doubt to ask here about video, Please Help me
How to remove the logo from DVD using virtualDubMod, i already download this software, but i dont know how to use this, I expect good answer from you people Please help me -
You can read https://forum.videohelp.com/threads/260207-Remove-Spoilers-Logos-etc
The screenshots doesn't work though...but you might get an idea how it works.
remove a logo using two videos
By mathmax in forum Newbie / General discussionsReplies: 32Last Post: 20th Sep 2011, 21:31 -
How to remove nasty animated logo?
By Bonie81 in forum EditingReplies: 4Last Post: 7th Jul 2011, 11:34 -
how do i remove logo
By gangers in forum EditingReplies: 1Last Post: 28th Apr 2010, 15:53 -
Remove Logo Without Re-encoding?
By midders in forum DVB / IPTVReplies: 2Last Post: 10th Nov 2008, 22:07 -
How to remove channel logo?
By dapix in forum EditingReplies: 10Last Post: 23rd Jun 2007, 11:06
