Does anyone know why an AVI that plays perfectly would go out of sync at a certain point in the movie (around 20 min in) when I author it to DVD?
It is at 29.97 fps so I didn't change the audio at all. Just encoded it to MP2.
I also tried using a step-by-step DVD author called FAVC. It encoded audio to AC3 using Aften and still had the same problem.
The avi is probably corrupt even if it's playable on the computer. Try scan for errors in the avi with virtualdub.
Your avi file probably has a little offset between audio and video before conversion, even though it seems as though it does not.
Try running the avi file through AVIMuxGUI per the instructions in this link:
https://forum.videohelp.com/viewtopic.php?p=1338598#1338598
Then create your DVD.
Mark -
There's one other possibility here.
Try the DVD in a real DVD player as opposed to a software player on your PC.
It's possible that you've created a perfectly good disc and something's corrupted within Windows.
Have fun,
Ian
Audio/video fine on PC, out of sync on Mac
By scrolls in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2012, 21:48 -
Avi: fine, DVD: audio out of sync
By Sebastian2011 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2012, 13:32 -
Video is out of sync (audio is fine)
By MaxNH in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2009, 10:55 -
DVD playback fine on computers, but not so fine on home players...
By stonesfan in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 17:03 -
Problem fine tuning audio sync
By spark001uk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2009, 14:02
