  1. Hi, I received a Liteon dvd recorder for christmas that can play divx and xvid files. I was wondering if and how I could make a menu for those files. I use to make DVD menus using dvd lab, but I'm not sure how to do it with divx files, any help is appreciated, thanks.
    USA
    If you have a DivX Ultra Certified player, you can use the newer Divx6, it can do menus. Otherwise, you will have to use the menus that the player generates.
