Ok, so normally if I convert avi to dvd using merge into one dvd and I burn the files then play it. After finishing the first episode, the second doesnt have any sound. So I dont know whats the problem is but then I choose to use merge into 1 title, and the dvd player read it well (sound and pic working great). So, I use that method to convert a series but now, I try to convert a new series into dvd. It doesnt work anymore, the conversion bar freeze at 17%. When I open what it has converted so far, its like at the end of the episode 1, so it freeze at begining of episode 2. You guys have any idea?
PS: one of the file have different dimension so I change them into the same but they have like different code or something ( one is xvid, one is dvixd or something). Is the code is the problem?
Thanks for helping.
Closed Thread
Don't double post, please.
Continue here: https://forum.videohelp.com/viewtopic.php?t=312799
/Mats
No sound upon conversion from RMVB to DVD using WinAVI Video Converter
By kris2099 in forum Newbie / General discussionsReplies: 12Last Post: 19th Sep 2010, 16:28 -
Help needed for video conversion : Winavi
By leoboms in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2010, 13:48 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
WinAVI 8.0 - DVD to AVI - Target Size 700MB?
By ivisitpublix in forum DVD RippingReplies: 2Last Post: 24th Aug 2007, 13:01
