I must delay audio, because it starts faster. A good advice would be without converting the streams. Thanks.
Results 1 to 11 of 11
Originally Posted by Baldrick
I tryed videoredo and while previewing i noticed, that it slows down or quickens audio, I don't need this. -
MPEGVCR is a full featured, frame accurate MPEG-1/2 editor. It contains some tools such as a demuxer and muxer. The muxer has an option where you can specify an amount to offset the audio in the mux, either positive or negative. This tool has fixed a lot of sync problems for me in the past. Maybe it would help you too.
Originally Posted by jman98
Originally Posted by romkeris
Estimating was wrong, the output size after procesing was good, but while playing video stops sometimes, maybe because of high bitrate of audio 384. I wil try to lower it. -
In mpeg-vcr deosn't know what means "MPEG-2 program stream" and "MPEG-2 transport stream".
I switched to "MPEG-2 program stream" and seems that everything is ok. The only thing is that is hard to find exact match, because there is no preview, tryed SyncView, but it shows wrong.
MXCapture program w/ Monster X - Audio Sync Issue
By Mysteriouskk in forum Capturing and VCRReplies: 3Last Post: 20th Jul 2012, 16:26 -
Program to visually sync audio and video?
By rayden54 in forum AudioReplies: 4Last Post: 14th Dec 2011, 06:38 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
Demuxed mpeg to mv2,mp2 with command line
By vtr in forum ProgrammingReplies: 4Last Post: 15th Sep 2008, 02:22
