Closed Thread
  1. I made this other tread, but its of in the wrong section, plus nobody has replied in the past 5 days. (https://forum.videohelp.com/viewtopic.php?p=1567773) I am hoping people who do not visit that section will notice this here with the BETTER title...
    Here is my problem: I used DVD Decrypter to get the whole DVD of futurama (before I left for college). It will run fine using CyberLink PowerDVD, but when I try to make them into an AVI the audio is always out of sync...
    If I go to volume 4, they have 2 vobs per episode. If I take the audio out using DGIndex the audio is 19:25, but the video is 13:10...
    Why is it doing this? How can I fix it?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Sounds like you don't have all of the video. Episodes run approx. 20 minutes, so the audio length appears correct.
    Try using AutoGK to perform the conversion.
    Google is your Friend
  3. I already tried AutoGK...
    This is ridiculous... I just played the video file for like 2-3m beside the vob and it was in sync, but when I wanted to jump ahead (on both of them instead of waiting the extra 10m) suddenly the video was out of sync, even if I went back to the 2-3m part (its like progress bar was at the wrong spot)...
    edit I just tried to uncompress the whole video, and it turned into 19:50.... Still almost 1m to much, and the audio was out of sync...
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Having sync issues while playing the whole video and having sync issues after seeking are two separate problems.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    please continue your first topic. or else will we just suggest same stuff again and again...
