Hi,
I read through many posts about using DVD Decrypter's ISO Read to read a dual layer DVD and then using ImgBurn to write the ISO onto the DVD +R DL disc.
I tried this with a dvd and the ISO Read was successful (or so I thought). But this is what I get when I try to burn the DVD:
Optimal L1 Data Zone Start LBA. None Found (VTS_01)
This Image Has Not Been Mastered Correctly for Burning onta a Double Layer (OTP Track Path) Disc.
None of the Cells meet the 'DVD-Video Specification' criteria for a potential Layer Break Position
The settings on DVD Decrypter are the default settings and so are the settings on ImgBurn.
My DVD burner is a TSST TS-H552B GA02(ATA)
What could be going on?
You might read this thread: https://forum.videohelp.com/viewtopic.php?p=1563121#1563121
And if you are not using it, there is a newer version of ImgBurn, V2 that may help.
And welcome to our forums.
Thank you very much.Originally Posted by redwudz
Actually I am using ImgBurn v2 and the latest version of DVD Decrypter (which is 3.5.4.0 or something like that). Well what I did anyways is that I used the ISO Write on DVD Decrypter and everything worked fine, well somewhat...
I was able to burn the DVD and was able to get to the main menu but when I try to play the movie, it froze on the FBI Warning section. Howeve I was able to bypass that by going to the chapter section and selecting the first chapter. I guess I can use PGCEdit to bypass the FBI Warning.
Which leaves me a question, If I was to use Vobblanker to blank out or cut out that FBI warning do I have to use IFOEdit to update the changes I made? If so then how? -
Does the source disc use PTP ?
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Burning AVCHD File To Dual Layer DVD
By Falco21 in forum Authoring (Blu-ray)Replies: 4Last Post: 15th Mar 2011, 12:16 -
Dual-Layer burning of DVD using nero?
By mr_jbloggs in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2008, 08:26 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Burning dual layer dvd-r from mac the ripper
By alforra in forum MacReplies: 11Last Post: 18th Apr 2008, 22:08
