What do YOU use?Envelopes / albums, regular jewel cases, or DVD-only cases?
Results 1 to 16 of 16
Jewel cases or DVD cases only. I would never put my optical inside anything that forces the disc surface to rub against something such as an envelope.
I only use envelopes for CDs, never DVDs, and even then I'm careful. For DVDs I'll use either of the other two.
TANSTAAFL -
On sale at one of those dollar stores I found what I can only call "wall sheets" for CDs/DVDs, they hold (flat) 24 DVDs, 4 across, 6 down, clear plastic face and some kind of soft fabric lining. I keep a couple hanging on the wall next to my computer because I can read all the labels at the same time (I have trouble reading fine print so I like BIG LABELS!) ... okay, they're not really labeled, I just write on 'em with a Sharpie ...
Anyway, these work great for me and I wish I could find more; they make it easy for me to see when a disc is not put back, and whatever the soft lining stuff is, I've not had even the slightest scratch on any disc yet and I've had these for a couple of years now.
Didn't somebody else just ask me that?
:P
Well, for me, it's Friday and I'm bored and my brain can't figure out any technical answers around here today, so it's down to Sharpies and crayons for something to do.
I've used paper DVD envelopes from the get-go and have never encountered any problems. However, if I was to travel with them anywhere, I'd put them in those plastic-windowed DVD/CD wallets. The only time a DVD has ever failed on me is when I:
1) Used a shitty brand - use only Taiyo-Yuden now.
2) When I did something stupid like drop one on the floor, not notice it, and (sigh) step on it.
And once, I spilled a cup of coffee on a few DVDs (in envelopes). But I cleaned them up with fresh tepid water, cloth-dried them, and they all worked afterward. Of course, I stored them in new envelopes (grin).
Anyhoo, there's a sale on at SuperMediaStore - 100 Taiyo-Yuden 4x DVD-Rs for $19.99. Here's the particulars:
https://forum.videohelp.com/viewtopic.php?p=1566877#1566877
Some of each, although mostly just DVD cases for DVDs and Jewel cases for CDs. I have used these Click Here for years for my VCDs, but haven't used them since I switched to DVD. I occasionally use envelopes/sleeves for handouts and short term. I figure if they're good enough for software providers, they're good enough for me.
Buy My Books -
I started with 12 disk wallets at CDN$1 each from Dollarama. Moved to the west coast of Canada and could not find equivalents, so I used 25 disk spindles for some time.
I finally switched to large wallets that hold 8 disks per page (4 on each side in a 2X2 array). They are advertised to hold 240 disks, but I find that they max out around 200. The extra sheets fit well in a North American style 3 ring binder. Make sure to get the D-ring style, not the circular ring style.
I went through two large boxes of audio CDs and gave away the jewel cases. I kept the paper inserts and was able to fit my entire audio CD collection into one large wallet.
I bought the wallet at http://www.xscargo.com/ for CDN$15 -
Paper sleeves for mailing. Rubber band the stack.
Plastic disc guard cases for mailing. Tape them shut.
Clear plastic sleeves, never, scratches discs.
Spindles for stuff I don't access often. Not suggested for lots of in-out.
Jewel cases (slim or full) or DVD cases for stuff I do access often.
Wallets for things I rarely use or need. These scratch too much for regular in-out use.Want my help? Ask here! (not via PM!)
Lordsmurf: You mentioned clear plastic sleaves and that they don't scratch the DVD's. I am running out of space for my DVD discs. Lately I have been buying Decuple Cases, that hold ten DVD's and are not much bigger than a VHS tape. Well anyway I have read on the forumn that the backing in the CD Wallets can scratch the discs, so I stopped buying them.
At blankmedia.ca, I found a product, and I am thinking of buying it. It says it will hold over 500 discs, and they are placed in "Indexed Plastic Sleeves". Do you think this would be a good product for those of us who just don't have the space to keep buying the Plastic Cases.
Here is a link to the product.
http://blankmedia.ca/proddetail3.asp?id=1091
Has anyone bought one of these and what do you think of them? Truthfully, I really need to find a place to store my discs that is compact and won't damage them. Our house is really small, and I have simply ran out of space. I hoping that product that I gave a link to could be a solution, that would be a good match for my situation. -
Have you thought about DVD cases that hold more than 1 disc, I have some that hold 4 in the space required for a one DVD caseThe ones that hold 10 DVDs take up approx 3 DVDs worth of space. I also tried some that hold 5 DVDs in a one DVD space but due to the design I was somewhat worried they'd scuff the other DVDs. IE two in the fron that overlap likewise in the back and 1 in a center divider.
I do like the ones that hold 1 disc per side... IOW 1 on the front, one on the back of the case and two per divider. They are now available in sizes to 12 discs. Great for series. -
TBoneit: I do use the cases that hold more than one disc. The Decuple Cases that I get at Effectuality.ca, hold ten DVDs. But even these add up to take significant space after awhile. Thank you for your input.
I think my feelings on the case you posted are that at first glance it looks like a good idea. Howver I think you will end up getting fingerprints on the discs when you go to get them out to use them. I couldn't tell if they had any type of lifting device.
The other quibble is that the big print says "Aluminum Storage case", then they say " strong metallic finish", and "Hard plastic cover with aluminum edge". -
I can't understand why someone can't manufacture DVD Wallets with a backing that doesn't put scratches on the playable surface of the DVD's. I remember Lordsmurf once mentioned that the wallets leave "micro scratches". I know there are sleeves that are made of plastic that someone can put in binders, but they just don't seem all that appealing.
I like the idea of the wallets, because alot of discs in a small space, is appealing. Also that they zipper up, so no dust get to the discs, is a nice feature. One could litterly have a couple thousand DVD's on a bookshelf that take up little space.
TBoneit: Probably there are some drawbacks to that "Aluminum Storage Case". I usually try to get my finger into the hole in the middle of the DVD and another finger on the outer edge to grab DVDs and move them. If I couldn't do that with these sleeves, I would definetly get fingerprints on the playable side of the discs. It is a fact that most everything is made of plastic these days, and maybe the case won't be able to take much wear and tear. Knowing me I would probably want to stack them to save space, which probably isn't a good idea. I think I might just give this case a try, if I am pleased I will buy more, if not I will not waste more money on one. Thank you for your input on this topic.
DVD Storage Cases
By Tenacguy in forum MediaReplies: 6Last Post: 10th May 2010, 19:43 -
50 pk slim DVD cases
By zoobie in forum MediaReplies: 0Last Post: 14th Feb 2010, 19:53 -
Bad DVD Cases?
By Nitro89 in forum MediaReplies: 3Last Post: 27th Feb 2009, 10:34 -
DVD/CD Jewel Cases
By wulf109 in forum Off topicReplies: 3Last Post: 23rd Jul 2008, 18:13 -
Double DVD Cases
By royal007 in forum MediaReplies: 0Last Post: 16th Aug 2007, 19:45
