I read another post a while ago about fading in and out video in virtual dub, using a filter, I think it was frame tweeker. I have been looking at virtual dub filters and haven't found it yet. Does anyone know where to find that filter, or one that can do fade in/out on the video?
Results 1 to 11 of 11
Good day
Can anybody repeate the LINK to VirtualDub plugin [FADE in/out] vdf-framework-v1.1?
Can't find it anywhere. -
Hello.
---> http://www.hlinke.de/vdub-filter/FTWEAK11.ZIP ( Frame tweaker )
---> http://home.earthlink.net/~tacosalad/video/fadefx.htm
---> https://forum.videohelp.com/threads/269425-Fade-in-Fade-out-filter-VirtualDub-MOD
---> https://www.youtube.com/watch?v=B4QJCDg2mXY
---> http://www.hlinke.de/tinc?key=U4rlLOrY&session_currentpage=data&session_mode=guest&for...ssion_start=21
Best regards.
devil (johner)Last edited by devilcoelhodog; 24th Jan 2016 at 11:58.
oh..
Question;
I need FADE between two sequenses - to join with fade.
Is it possible in Dub generally? -
As long as it's realized that FadeIO(50) will add two frames to the video. To keep the same framecount it should maybe be written as:
FadeIO0(50) -
You can use most filters that come with Virtualdub to create fades as long as they have a Blend option. You'll have to experiment to find the ones you like.
The Fill filter in Blend mode with the Curve Editor is the most natural fade filter. You can fade in and out from black or any other color and make as many fades as you need by creating a curve at each scene change.
Do a search here and you will find step by step guides.
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 22:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 04:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
