You might try this one instead...
http://home.earthlink.net/~tacosalad/video/fadefx.htm
Click on the FadeFX.vdf to download the file. -
You're welcome. I don't know what happed to the Fader.vdf link but it is definately dead.
I've been using Virtualdub 1.7.2 and there are different ways of getting a fade in fade out effect using the Blend option and Curve Editor.
I was using the Brightness filter at the black setting in Build 27169 but that isn't working in Build 27700 so I've been using the Fill filter. What is cool about this filter is that you can fade to whatever color you want.
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 08:23 -
Fade in Transition Fade out scenes
By ancient in forum Authoring (DVD)Replies: 4Last Post: 30th Nov 2007, 05:04 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 16:02 -
fade in/fade out with smart rendering
By bmf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jun 2007, 13:33
