  1. I have various recordings at different dates, with different artists on each date. I wish to know if it is possible, and how to, create a menu where I can select to see all recordings for a date, or select a specific artist for all of the dates. I have been reading a lot but have not seen (or at least recognised) how to do it. Can anyone give me at least a hint so I can get to the right direction?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Sounds like a simple task for DVD-Lab (among other)
    One root menu that lets you select Time or Artist menu
    On the Time menu, you make a "pick date" menu, leading to individual date menus, where you list all recordings for that date.
    On the Artist menu, you list all artists, leading to one menu for each artist with the recordings for that artist.
    /Mats
    Feb 2004
    Australia
    Dvdauthorgui for basic dvd authoring .
    The gimp , or other for creating menu's (you will need to make chapter menu's as well for what you want to do)
    Pgcedit for correcting and editing dvd nav command's ... quick at fixing nav error's .
    Koolplaya ... for dvd playback from folder .
    Depending on clip type :
    If avi ... try the vdub frameserving guide .
    If mpeg2 ... try my commercial removal guide .
    As for how to go about putting it together ... check out mpeg to dvd easy guide ... advanced is music dvd guide ... serious is slideshow guide .
    The problem is you will want to maybe have .
    Function that play's all clip's of one artist .
    Function to play clip's from specific date .
    And function to play artist clip's , on or from a specified date
    Same gose for all artist's , on a specified date , or from .
    For me it's simple ... so have a look at these guide's will give you a good starting point ... if you can master these , you can do anything .
    Guide's to show you various way's
    Slide show's
    https://forum.videohelp.com/viewtopic.php?t=296748
    Commercial removal
    https://forum.videohelp.com/viewtopic.php?t=291744
    Dvd compilations made easy
    https://forum.videohelp.com/viewtopic.php?t=270121
    Make your own subtitle's
    https://forum.videohelp.com/viewtopic.php?t=291971
    Reposition subtitle's
    https://forum.videohelp.com/viewtopic.php?t=291741
    Button's for dvdauthorgui
    https://forum.videohelp.com/viewtopic.php?t=285839
    Frameserving in vdub ... just incase
    https://forum.videohelp.com/viewtopic.php?t=270071
    Music video dvd's
    https://forum.videohelp.com/viewtopic.php?t=270620
    Mpeg to dvd easy
    https://forum.videohelp.com/viewtopic.php?t=269499
    Should just about cover most thing's ...
  4. Thanks for your quick response. Thanks to your guidance I have a clearer direction on where to go. There is some more homework to do now!
