I have an mpg file which does not play with Windows Media Player but does play with VLC Media Player. I tried loading it into TMPGEnc, into Mainconcept MPEG Encoder, into AVIdemux and into Canopus Procoder, but none of these would read the file or gave me error messages.
What I am trying to do is convert into a standard 720x480, 29fps file so that I can author it onto a DVD. Again, the strange thing is that the only appcication that reads it is VLC Player, which prooves that this file is somehow "readable".
Gspot diagnoses an "Unknown" file type and AVIcodec does not even load the file to be analyzed. VLC Player shows: Video Codec: mp4v and Audio Codec: mpga
What can I do? Is there another application that I can use to try to convert this?
Thanks in advance for any guidance provided.
Results 1 to 11 of 11
Thanks for the reply.
I am using GSpot 2.5 beta and all I get under the "container" section is: File Type: Unknown, Mime Type: Unknown
"Stream and Media Info", with VLC Media Player gives me:
Stream 0:
- Codec: mp4v
- Language:
- Type: Video
Stream 1:
- Codec: mpga
- Language:
- Type: Audio
Any other alternatives? thanks. -
Is the file extension .mpg? I think it may actually be an .mp4 file. Media Player Classic should be able to play it as well, but you might need an MP4 splitter to get WMP to play it.
Being a misnamed mp4 would probably explain why the editors won't touch it - they're expecting MPEG-1 or MPEG-2 data, and not finding it.
(makes mental note to start paying attention when I reply to posts...
If cameras add ten pounds, why would people want to eat them? -
Thanks again for the reply-
The file extension is mpg. Is this a matter of just changing the extension to mp4? What is an mp4 splitter and where can I get one?
thanks. -
I'd be guessing , from that info it's an mp4 with mpeg audio , either layer 1 or layer 2 type ... normally the first .
Coped one of those the other day from a friend ... use mp4cam2avi to convert it to avi containing xvid + mp3 ...
Depending on it's size ... scaling it up is never really good on pc's ... but
Load it into movie maker , make sure the "make clip's" function is enabled .
Save project .
Build 3 minute's on timeline .
Save to pc as dv avi .
Convert exported dv avi (type 1) to dv2 (converter in tool's section)
Delete dv1 avi .
Do next clip ... add 2 on "untitled" name , so you know the order .
Repeat above step's .
Next clip out "untitled" 3 ...
Delete project before closing movie maker .
Open untitled (first clip) in vdub .
File , append , load second part .
File , append , load third part .
Continue till all have been added in correct order under "append method"
What was original frame rate ?
Hold ctrl , press r ... second edit box , enter original frame rate here .
Next
Video compression , choose xvid ... 2400 or higher
Audio , set to full processing ... next is audio compression ... mpeg layer 3 (48kbit/s 24,000 hz , 6 kb/s) .
Save as avi .
Framerate conversion .
Super , drag and drop this new avi into video list window down below .
Set video out to mp2 , 48hz (no lower than 96kbit/s)
If video is not near full dvd res , consider option's .
Pal :
352x576
352x288
Ntsc
352x480
352x240
Choose type from this list .
Framerate conversion ... choose required value .
Let super convert file to mpeg2 and given parameter's .
Use batchdemux to pull video and audio stream from mpeg
Audio may have extension as mpa , rename extension to mp2 .
Convert mp2 to ac3 using besweet .
Use rejig to author m2v and ac3 into dvd title .
Should you need to mix different resolution vob title's :
Use dvdauthorgui to create a basic dvd with menu's and enough button's for all navigational requirement's .
Add one FULL d1 resolution clip (can be ripped logo from dvd ... demuxed into m2v and audio stream ... convert audio to ac3)
Connect menu's to menu's (main to chapter ... ect)
All button's related to title's commect to title one for now .
Author dvd to folder .
Save project for later (backup incase you forgot to add some button's , ect)
Open authored title in pgcedit .
From here , take a look at some of my guide's :
Slide show's
https://forum.videohelp.com/viewtopic.php?t=296748
Commercial removal
https://forum.videohelp.com/viewtopic.php?t=291744
Dvd compilations made easy
https://forum.videohelp.com/viewtopic.php?t=270121
Make your own subtitle's
https://forum.videohelp.com/viewtopic.php?t=291971
Reposition subtitle's
https://forum.videohelp.com/viewtopic.php?t=291741
Button's for dvdauthorgui
https://forum.videohelp.com/viewtopic.php?t=285839
Frameserving in vdub ... just incase
https://forum.videohelp.com/viewtopic.php?t=270071
Music video dvd's
https://forum.videohelp.com/viewtopic.php?t=270620
Mpeg to dvd easy
https://forum.videohelp.com/viewtopic.php?t=269499
Should just about cover most thing's ... -
celtic_druid: Yes, I am using AviDemux 2.2 and when I try to open the file, the application just crashes giving me a message:
Microsof Visual C++ Runtime Library
- Assertion Failed! -
Program: C:\Program Files\Avidemux\avidemux2.exe
File: dmx_video.cpp
Line: 106
Expression: 0
Bjs: I tried loading the file into Mp4Cam2AVI but since it has a mpg extension, it would not even let me see it in the source section so I changed the extension to mp4. I was then able to see it as a source, I selected the file and pressed "Preview Playlist" and got a message: ERROR: moov atom not found. I then pressed Start and the application just froze.
This one seems like quite a challenge, doesn't it? If there are any other alternatives that you can think of, I would greatly appreciate it if you could please let me know.
Thanks. -
Ok, as ridiculous as this may seem and given that none of the kind suggestions provided worked, is there a tool out there that can capture the video and audio as played on the VLC Media Player? I am thinking of a tool that might allow to select certain section of the screen and "record" whatever happens on that section. Is there such thing?
Thanks. -
Amazing! It was that simple! VLC did it all!
What I could not convert with any of those other tools I tried, I was able to convert with VLC. I had no idea that VLC Media Player also encoded. What a powerful little tool that one is!
Thanks celtic_druid! Great discovery!
Thank you all for your advice.
Trouble converting 25FPS MKV file to 24FPS
By dave in or in forum Video ConversionReplies: 3Last Post: 29th Jul 2011, 22:46 -
(Sound Problem) Converting karaoke Vob file to mpg/ other video type cause.
By kiangtong in forum Video ConversionReplies: 1Last Post: 23rd Jan 2010, 04:45 -
Trouble converting mpg
By Jeffrey99 in forum Video ConversionReplies: 4Last Post: 13th May 2009, 07:59 -
Trouble converting .mov to mpg
By jay_lubb in forum Video ConversionReplies: 1Last Post: 9th Mar 2009, 03:14 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 12:39
