how to convert dvd with 78 PGC into divx? if it would be 1 VTS with 1 PGC, everything's clear. but now? any help would be appreciated...
Depends on the way the DVD is authored, and what exactly you want to convert to divx, but here's two links that might assist:
https://forum.videohelp.com/viewtopic.php?p=1373527#1373527
https://www.videohelp.com/guides.php?guideid=625#625If in doubt, Google it. -
there's VTS_01 with 78 PGC's. and i want to convert all of them.
but when i tried with command file, i had problems.
when i started command file with command lines, it opens dvd decrypter, then i have to press decrypt button. but: 1) program starts decrypt into another folder, not into my created and which is in command line; 2) after decrypting PGC 1, i push decrypt button, and program wants to decrypt into the same folder and asks overwrite or rename files... it seems like command file doesn't work correctly... it doesn't decrypt PGC 2.
what's wrong??
i tried in another way - with ifoedit and smart ripper. but: 1) i had message in IFOEdit:
*1 out of 3 DVD streams failed to render properly.
- subpicture stream.
Do you still want to continue?...
2) when i pressed DVD Play button, it plays, but in DVD Play window Title and Chapter windows aren't active;
3) after opening smartripper, i can't select all angles. only one chapter appears in chapters window
what's wrong?
How to add your own subtitle to DVD (keep menu, multi-pgc)
By bluedha in forum User guidesReplies: 339Last Post: 10th Oct 2013, 20:11 -
DVD with weird PGC structure
By lordretsudo in forum SubtitleReplies: 3Last Post: 11th Jul 2011, 06:25 -
Print DVD Information (VTS - PGC)
By dw-wizard in forum DVD RippingReplies: 0Last Post: 27th Sep 2010, 14:54 -
rip DVD content by VTS, instead of PGC?
By lordsmurf in forum DVD RippingReplies: 7Last Post: 28th May 2009, 10:35 -
Tracing which PGC is played when a DVD menu button is clicked
By Cheekie_Moonkie in forum Authoring (DVD)Replies: 3Last Post: 5th Sep 2007, 14:29
