When converting a divx avi file to DVD, what are the absolute best settings
to use for maximum quality?
I usually use:
DVD ffmpeg
High Quality
Two-Pass Encoding
The output although good, is noticibly inferior to the standard output of say
DivxToDvd on windoze which I usually run in virtualised window with Parallels
Workstation. I'm a mac guy and I want to use mac only!
Would mpeg2enc be better? If so, which options are best (size no issue)?
You could activate Use B-frames, 4 motion vectors and Trellis quantization as well for more quality. And bump the bitrate. And lower the Qmax.
Can you link to screenshots of this noticeable inferiority? Same scene for both encoders please.
The developer seems to think ffmpeg beats mpeg2enc output quality-wise.
Confusion about DivX-Encoding settings
By foxhunter in forum Newbie / General discussionsReplies: 37Last Post: 23rd Jul 2009, 12:26 -
DVD to DivX - settings for better quality
By CodeMaster2008 in forum DVD RippingReplies: 11Last Post: 14th Jul 2009, 04:20 -
Recommended settings for dvd to divx ?
By jimcgr in forum DVD RippingReplies: 6Last Post: 11th Feb 2008, 08:25 -
Dr. DivX subtitle settings
By drstupid in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 08:13 -
Configuring settings when converting to AVI (DivX codec)
By firas_hashim in forum Video ConversionReplies: 15Last Post: 24th Jun 2007, 03:21
